Tycho Posted January 9, 2006 Share Posted January 9, 2006 I'd never seen it before. Substituting the wrong o ring + too much cam case sealant = ... (click the pic to see more pics) Pulled that criznap out, cleaned things up, cranked it ... poof ... (enjoy the) silence. Quote Link to comment Share on other sites More sharing options...
idosubaru Posted January 9, 2006 Share Posted January 9, 2006 seen an XT6 owner do this. tried reusing the cam carrier o-ring (the bottom corner one) with excessive sealant. it sucked up the sealant and caused same issues. anaerobic sealant all the way, this wouldn't have happened. i also took apart an ER27 tha ti picked up from someone and they installed a regular oring instead of the metal ring reinforced oring, glad i caught that ahead of time! Quote Link to comment Share on other sites More sharing options...
Qman Posted January 9, 2006 Share Posted January 9, 2006 How'd the cam look? People need to realize that some is good and more is bad! Quote Link to comment Share on other sites More sharing options...
Tycho Posted January 9, 2006 Author Share Posted January 9, 2006 Cam journals, lobes, the rocker pads, and the lifters themselves all looked fine. Low spring pressures + wide lobes / large journals was the saving grace there I'd say. These engines really are over engineered in many ways. As a note...there was no sealant sucked up. That's ALL o ring. Quote Link to comment Share on other sites More sharing options...
Subi81 Posted January 9, 2006 Share Posted January 9, 2006 That is f'ed up thanks for posting it. Quote Link to comment Share on other sites More sharing options...
