Slagathor1 Posted October 9, 2003 Share Posted October 9, 2003 Two reasons i'm putting a new timing belt in my 92' Loyale..One is that I need to pull the oil pump & either repair or replace it to get rid of that damn clicking from the valves ..I already tried the 50W oil & MMO trick (didn't work)..Since I have to pull the covers & belt to get to the pump, I might as well put a new belt on while i'm in there.. Second reason is i'm sure the belt is very worn (103,000 miles) & the engine just seems like it runs different everyday as far as being in time, almost like the belt is missing teeth & the timing is varying a few degrees back & forth.. ANYHOO, my question is: obviously I need to get the new oil pump seals & the timing belt..BUT, are there any other parts I should get while i'm out (such as the tensioners maybe??) I'd like this to be as smooth of a project as possible this weekend.. Believe me, I already know how those "easy" projects end up being nightmares sometimes..I'm already having visions of myself this weekend throwing tools across the yard:madder: , punching stationary objects:banghead: , & scaring the neighbors:moon: ..Hopefully it won't be that bad though:D ... Link to comment Share on other sites More sharing options...
Flowmastered87GL Posted October 9, 2003 Share Posted October 9, 2003 I suggest doing both belts, the cam seals, the front main seal, the oil pump seals (specifically the mickey mouse gasket), and the water pump (or just replace its gaskets.... it depends on how bad it looks) Also while you are there it would be nice to replace that little elbow hose that exits the top of the water pump and connects to a hard line which leads to a heater hose in the firewall. While stuff is off it wouldnt hurt to replace the V belts too and flush the coolant. Link to comment Share on other sites More sharing options...
Slagathor1 Posted October 9, 2003 Author Share Posted October 9, 2003 So there's 2 timing belts to replace under the covers??..I thought there was just one long one by the looks of the photos in my Haynes manual..Maybe I need to pour over their instructions again.. Do you usually need to replace the tensioners?? Link to comment Share on other sites More sharing options...
TomRhere Posted October 9, 2003 Share Posted October 9, 2003 Can't answer the 1 or 2 belt question, don't know what engine you have. But on the tensioners... They should be free spinning, no odd noises. and no wobble side to side. Also check the idler pulley, (it has cogs on it to match the crank and cam pulleys), same check as the idlers..... Link to comment Share on other sites More sharing options...
Flowmastered87GL Posted October 9, 2003 Share Posted October 9, 2003 If your car is a loyale then what I said applies... it has 2 belts. If it is a legacy then it has 1 belt.... not sure what you should do on them... I only had 1 legacy in my life and it was for a week Link to comment Share on other sites More sharing options...
MilesFox Posted October 9, 2003 Share Posted October 9, 2003 make sure tou read the haynes book text very well, because gong by the pictures alone will throw you off, happens to a few people, Link to comment Share on other sites More sharing options...
