Drivers side suspension "popping"
Have an 05 WRX with 18" Tarmacs and Falkens. Lowered using Tein springs and now there is a "pop" when a hard right hand turn is made that sounds like it is coming from behind my drivers side front wheel. It does make the care a bit loose in the curves during the "pop". It always happens in a hard righty. Any suggestions on fixing this? Email JSARMYOFONE@AOL.COM
Did you install them, or did someone else install them?
There is a cone shape washer that goes between the upper spring seat and mount. If that is left off or installed incorrectly, the spring seat will not pivot freely on the bearing in the mount.
That's where I'd start.
  • 2 weeks later...
  • 3 years later...
