ATTN All lifted EJ's
LosDiosDeVerde86
I've got a question/partial on-topic threadjack :)
If you stick OB struts in a leggy and you get the extra 1.5" of lift. How much harder is that on your CVs? -counter question- Isn't this basically the factory setup for an OB? Or does the OB come factory with different pumpkin/cradle mounting to allow for the lift?
Its a 4" AA lift that is just like the other lifts for our older vehicles except has 5 or six extra components, it lowers the engine four inches (so yes we lowered the engine to match the lift). With this lift you have to run outback struts or forrester struts, because the stock legacy struts will not fit larger tires. Either way you lift it you will have to put the struts on it (sorry for the eplanation I put it on here for the newbies). The only difference is the Outbacks/forresters come with a factory 1.5" lift, the legacy's do not. Although you can adjust the camber for the lift so you should have no problems when you put the struts on without a lift. (maybe a little positive camber).
This topic is now closed to further replies.
