General Alignment Questions
Two Questions:
Is there any mechanical damage to an un-aligned car? I know there will be damage to the tires and difficult steering/handling, but can this lead to mechanical damage in the differentials, or something else, also?
Once aligned, how long should it last? Is it pretty much once you drive off the mechanic's lot after alignment, it's in your own hands. 100... 1000... 2500 miles down the road and you're paying for a new alignment?
  mtbe said:
Two Questions:
no mechanical damage can occur and it's good to get an alignment about every 10 - 15k miles. depending on how many potholes you hit :banghead:
Being non mechanical: Yes, I'm the one that had the VCU failure.
The car has an unalignment problem now. It has been that way for maybe 1000-1500 miles. I thought maybe that could have caused the viscous coupling to fail and wanted to kick myself if that was the case.
Plus, I probably had the alignment done, at the dealer, 5000 miles ago. And now, it is worse than what it was before.
I did take it to a respected tire dealer and asked him about the wear (I wanted to change the tires) and he said that they were fine and I probably could get another 10,000 miles out of these. I do rotate them at 7500 miles, sometimes less.
