Timing Belt Check and Replacement Timing Belt Check and Adjustment The Timing Belts can be Visually inspected and Adjusted by removing the outer belt covers and the tensioner access plugs. To remove the outer belt covers, use a 10mm ¼” drive socket and remove the 3 bolts from both the left and right covers. The bolts thread into a brass fitting molded into the plastic. Be careful not to apply too much torque
