SOOBOUTLAW Posted January 15, 2006 Share Posted January 15, 2006 How do you get the input shaft carrier off the tranny? My chilton won't tell me.I need to fix an oil leak before i put the tranny in the rig. Link to comment Share on other sites More sharing options...
SOOBOUTLAW Posted January 15, 2006 Author Share Posted January 15, 2006 Ea81 D/r Link to comment Share on other sites More sharing options...
SOOBOUTLAW Posted January 17, 2006 Author Share Posted January 17, 2006 Does transmission work scare people? Link to comment Share on other sites More sharing options...
monstaru Posted January 17, 2006 Share Posted January 17, 2006 scares the hell out of me........ Link to comment Share on other sites More sharing options...
GLCraig Posted January 17, 2006 Share Posted January 17, 2006 I've taken many Subaru transmissions apart but it's been about 8 years since the last time. If I remember right you need to split the transmission case to get the carrier out because the gear at the end of it is a little bigger then the hole in the case. If it doesn't come out after removing the 3 bolts that hold it in, then you need to split the case. If it dose come out, make sure nothing drops down into the case. Link to comment Share on other sites More sharing options...
SOOBOUTLAW Posted January 18, 2006 Author Share Posted January 18, 2006 Thanks. I guess this will be the first transmission I have put 'under the knife'. Link to comment Share on other sites More sharing options...
