HELP: my 97 impreza obs clutch slips till engine heats up???
I need help. I own a 5 speed 97 impreza outback sport with approx. 188k miles. When the weather turned cold this winter my car started to exhibit a strange trait. When the engine is cold the engine will RPM high when accelerating but the car will not respond by going any faster. i have to ease off the gas and bring the RPM's low before the car will continue to push forard again. this will happen in any gear i use, preventing me from getting up to speed quickly, thus forcing me to be conservative. When the engine warms up though, the car will respond like it should and i can take it to the proper RPM, usually between 4 and 4500 RPM, before i upshift. If anyone has any ideas what this might be. please let me know. PS. In cold weather when starting my car my RPM's will go to 2-3K and usually the way to bring them down to normal is to rev the enging for a second. this will usually put it back in the 900 range. thanks again for any help.....
The high rpm's in cold weather starting is normal. 2-3k sounds a little high, but 1800 to 2k is normal in my GL in cold weather -- the computer is revving it to warm up faster. By hitting the gas, you are somehow telling it to stop that -- like hitting the gas after it starts to disengage the automatic choke on old carbureated cars, except this is all computer driven now.
Don't know about the clutch slipping thing.
