dave valiant Posted January 17, 2006 Share Posted January 17, 2006 I was going to put my new engine on an engine stand so that I could start putting the accesories on from the old motor. A guy I was talking to said that it would be a bad idea to put an assembled aluminun block engin on a stand. He said that the aluminum isn't strong enough and I would end up cracking the bellhousing. This sounds like a serious load of garbage, but having just dropped a little over a grand on this I just wanted a few opinions. Link to comment Share on other sites More sharing options...
NorthWet Posted January 17, 2006 Share Posted January 17, 2006 Are you sing the same 4 bolts that attach it to the tranny? I wouldn't worry too much, just don't abuse it. My EA82 seems happy hanging on my engine stand... hadn't even considered that the stress would be too much. Link to comment Share on other sites More sharing options...
kayakertom Posted January 17, 2006 Share Posted January 17, 2006 I've done it several times now without any problems. The longblock weight is around 250 lbs (110kg), so you really aren't stressing anything. It makes it so much easier to do the transferring pf parts. If you have any worries about your engine stand, use a bench with some wooden blocks under the oil pan until you are comfortable with the engine stand. dave valiant said: I was going to put my new engine on an engine stand so that I could start putting the accesories on from the old motor. A guy I was talking to said that it would be a bad idea to put an assembled aluminun block engin on a stand. He said that the aluminum isn't strong enough and I would end up cracking the bellhousing. This sounds like a serious load of garbage, but having just dropped a little over a grand on this I just wanted a few opinions. Link to comment Share on other sites More sharing options...
subiemech85 Posted January 17, 2006 Share Posted January 17, 2006 I used a tire and pallet when I had to pull out the ea81 Link to comment Share on other sites More sharing options...
Hodaka Rider Posted January 17, 2006 Share Posted January 17, 2006 dave valiant said: I was going to put my new engine on an engine stand so that I could start putting the accesories on from the old motor. A guy I was talking to said that it would be a bad idea to put an assembled aluminun block engin on a stand. He said that the aluminum isn't strong enough and I would end up cracking the bellhousing. This sounds like a serious load of garbage, but having just dropped a little over a grand on this I just wanted a few opinions. Just tell him it's Japanese aluminum and metric bolts, and that it'll hold just fine. Link to comment Share on other sites More sharing options...
BoostedBalls Posted January 17, 2006 Share Posted January 17, 2006 Mine has been sitting on the stand for a couple months now and I'm only using two bolts to hold it in place! I've torqued the heads, bounced it around over air hoses etc in my shop and it's still hanging with no worries. Link to comment Share on other sites More sharing options...
Flowmastered87GL Posted January 17, 2006 Share Posted January 17, 2006 I've used my engine stand with 2 bolts (the top of the bell housing) and nuts on them... just finger tight.... then I slide the 2 studs on the bottom of the engine into the bottom of the 2 holes... I dont bother with nuts on those because the studs are too short to put a nut on with the current mounts on my stand. Ive had EA82's and 81's on there with no, some or all of their accessories and never had a problem yet. I HAVE on the other hand cracked a bell housing on an EA81 trying to use a breaker bar to keep the flywheel from turning so we could change the front main seal. We gave up and left it after it cracked... the seal wasnt leaking anyway. Link to comment Share on other sites More sharing options...
dave valiant Posted January 17, 2006 Author Share Posted January 17, 2006 I pretty much thought the guy was full of it, but wanted to hear from experience. Thanks guys. Link to comment Share on other sites More sharing options...
ballitch Posted January 17, 2006 Share Posted January 17, 2006 ya that guy was F.O.S. i have an EJ25 on the engine stand right now with top holes finger tight. been that way for 3 months now. ~Josh~ Link to comment Share on other sites More sharing options...
Qman Posted January 17, 2006 Share Posted January 17, 2006 2.7 on the stand for 6 months +. A couple of others as well. Definitely FOS! Link to comment Share on other sites More sharing options...
Subarian Posted January 17, 2006 Share Posted January 17, 2006 I'd be really careful about any other advice the guy has for you, too. Link to comment Share on other sites More sharing options...
