Front Brake Question!!!
In the process of changing out front brake pads on a 1986 gl wagon and didn't realize I needed a special tool (I have it now) to compress and turn in piston.. So last night before I realized this, I pressed on the piston a little with a big C-clamp!! Does anyone think I might have damaged the threads in the piston???
Thanks in advance!!
Actually the rubber boot around the piston is riped and partially missing?? What now??
No I don't think you damaged anything.As long as the rubber seal around the caliper piston isn't cracked then there shouldn't be anything to worry about.Those calipers are pretty strong.
Wont have done any harm, and you dont need to use the special tool - various other things do the job, a large ROE spanner with a screwdriver through the ring end works well. Linemans pliers work well too.
