mortimc Posted January 18, 2006 Share Posted January 18, 2006 Both of the motor mounts on my 81 subie sheared on the plate that is attached to the block. Has anyone had any sort of problems like this, if so, what did you do. I just welded the pieces back together without reinforcing them (didnt know what clearence problems I might create). This is temporary for now, I expect them to crack again in the heat affected zone pretty soon. But, they're pretty easy to pull in and out if anyone has a brilliant idea. Clayton Bellingham Link to comment Share on other sites More sharing options...
monstaru Posted January 18, 2006 Share Posted January 18, 2006 if you need some good used ones i have some........send me shipping and they are yours.i hate to see you ruin a perfectly good car.pm me your addy or put it here..... Link to comment Share on other sites More sharing options...
mortimc Posted January 18, 2006 Author Share Posted January 18, 2006 Thanks, I live in Bellingham, WA. So that would work out pretty well. Ill see if I can find some tomorow, if not I'll let ya know. I was thinking it would be a good idea to reinforce them somehow because thay have a lot of sheer stress loaded through 'em, but I dunno where to start. Clayton Link to comment Share on other sites More sharing options...
subarunuts Posted January 18, 2006 Share Posted January 18, 2006 The EA81 mounts always shear like that for some reason... old rubber I suppose. Best thing is to either get some new ones, or make some of your own with some two part urethane. Can get new ones here: http://www.rockauto.com/ Link to comment Share on other sites More sharing options...
CHIM Posted January 18, 2006 Share Posted January 18, 2006 lol, i have broke so many motor mounts!!!, i have a problem with dumpimg my clutch at stoplights:lol: , Even dented the hood on my old 81 from the motor hitting it. Link to comment Share on other sites More sharing options...
BlueSteel Posted January 19, 2006 Share Posted January 19, 2006 i know the round ones of the early liberty's (legacy) work well and bolt straight in lots of rubber in those, no where near as likely to break Link to comment Share on other sites More sharing options...
mortimc Posted January 19, 2006 Author Share Posted January 19, 2006 I think you guys think im talking about the rubber part, to clarify, the parts that broke are the plates between the rubber blocks and the motor itself. Clayton Bellingham Link to comment Share on other sites More sharing options...
ballitch Posted January 19, 2006 Share Posted January 19, 2006 so the rubber itself is fine, you just broke the metal pieces that attach rubber to motor, and rubber to crossmember? that sounds like a feat if ive ever heard one. id take him up on the motor mounts if i were you. ~Josh~ Link to comment Share on other sites More sharing options...
