i've broken 3 sockets and breaker bars. got a 3/4" drive finally and put a huge pipe on it, works like a charm. 1/2" just won't stand up to some axle nuts (alot of them in my experience).
spring for the 3/4" if you can, i finally did at the advice of others and i'm glad i bought that thing when i did, should have done it early.
and saftey note - that's why you wear goggles when doing this stuff...or should, most of us forget on something like that or don't think about it. we have a member at xt6.net that got hit in the eye, not a good thing he made out okay considering what could have happened, but still not good.
LOL I did that to TWO Craftsman 1/2" breakers (the 2' ones) steel pipe and everything! On a 36mm axle nut on a honda accord. ROFL. Except mine twisted off real clean and left the stub inside the socket. After I broke the second one I took the car to Big O Tires and had them use an impact gun on it.
wow... holy crap... I forgot who made my breaker bars(they're like 50yrs old, company probably doesnt exist anymore..), i've put a peice of 4ft pipe on em and used it with my floorjack(4 ton...) and I've always broken the bolts/studs/nuts and the occasional socket, but never broken a breaker bar....
it seems that i'm going to need alot more PB blaster, and a new breaker bar....
The pic certainly provides a new perspective on "breaker".
I guess i should keep the 5ft steel pipe away from the new one...
Yeah, that bar seems to be allergic to your "torque multiplier". ;)
I have had very poor luck with breaker bars. I have broken two 3/8" ones, on little 17 mm nuts! One was a no-name cheapy, but one was a Bluepoint from the 1940's.
Once I saw a 1/2" one break on a VW Rabbit lug bolt. That one was a cheapie, though.
For 1/2" I have a sliding t-bar that seems to be able to take a 3 ft pipe.
Neversieze when reassembling makes the next time so much easier...
ive broken a 1/2'' socket wrench on axle nuts, and bent the crap out of the neck of my dads breaker bar. i should really buy a 3/4'' breaker bar, but that socket and flatbar combo idea sounds like a winner to me. just weld on a 3-4ft piece of 1/4'' by 2'' steel bar and your good to go.
~Josh~
You'll find most old tools are like that. They just don't make stuff how they used to. Unless you buy the ultra super duper expencive tools.
The only drawback is it limits the use of the socket for other applications. The good part is usually a socket of that size doesn't fit any other places and you probably bought it special for use only on the axle nuts. Actually what prompted me to weld up a bar the first time was after I broke a 1/2" breaker just like the one in the picture.
Rollie
One axel nut I fought with took out two 1/2" breakers, and a 1/2" ratchet. The socket attached to an impact wrench did nothing. Took a heavu duty impact socket on the impact wrench (and about half a can of PB Blaster) but the thing came off. I always win. . .eventualy.
How do you keep the axle from turning when you are trying to get the nut off? Keep it in gear? Push on the brakes?
in gear (i think 5th??). loosen the bolt first while the car is on the ground so you have the weight on the wheel. just loosen it, then jack it up and take it off completely. block the car somehow so it won't "roll" as you're cranking on it. if it can't go anywhere, the nut has to back off. holding brakes on can help.
we were holding the brakes while doing it... my friend had to hold onto the steering wheel pretty tight too as to not have that turn alot too :brow:
Yipes.
One thing I've done is taken an old broken ratchet, and welded the ratchet solid, and I use that when I'm planning to beat on it. Welding the steel bar directly to the socket sounds like a good idea too.
I've used a big adjustable wrench for axle nuts too -- sometimes I've used the starter motor in first gear (or reverse) to turn the axle to break it free.
kinda funny story...
i was trying to get a lego nut off and couldnt had just broken my S&K 1/2 braker bar. well in walks the snapon guy. and i said ill buy your bigest 1/2 impact gun if it will take this off. well he started drolling and ran to the truck,
outcome
110lb s of air pressure. snapon gun just sat there and rattled.
it was funny to see the look on his face...
so i took a die grinder and cut the nut up and off it came.
My harbor freight electric impact tool does 95% of the axle nuts I've tried; the other 5% get my 4 foot extension on my 1/2" breaker bar...it's a craftsman and I've only had to replace one in 5 years. For the really difficult ones at Pull a Part where the brakes are useless and the wheels are in the air, I have a steel rim with a two foot bar welded on it to keep the hub from turning. I just bolt on the rim and prop up the bar a crank on the breaker bar.
outcome
One thing I've found why it is harder to take off the nut while the car is on the ground. The reason? Well, when the car is sitting on the ground, the weigh of the vehicle adds to the pressure of the nut and bearing, so it would take much more work to make it come off. I work as an auto mechanic and I tried that on my own car. I even used a 1000 lbs impact gun on it and it still didn't bulge. As soon as I lifted the vehicle off the ground, I didn't even use a 1000 lbs impact gun, just a 500 lbs gun and it came right off easily.
You may not realize how much pressure is added to the axle nut when the car is sitting on ground, but it's a lot. I found it out by doing an actual experiment on my own car. The only problem is for those that don't have impact gun, it's going to be tough no matter what. But for those that have tried impact gun without success while the car is on the ground, lift the car (or just that particular wheel/side) and it will be so much easier.
Hope this helps someone save a breaker bar or two, not to mention some harms that may cause oneself as a result of breaking something.
the steel rim junkyard tool is a good idea, I have always just taken my largest pipe wrench with me when axel hunting, has always worked so far. I have yet to break my 1/2 s/k breaker bar and i've used a 4ft pipe on a legacy front axel, ended up chiseling the mother off!
