bob393 Posted January 20, 2006 Share Posted January 20, 2006 Hi The electric choke just stoped working. I checked and there is no voltage at the terminal. I ran a jumper from an ignition source and now it works. Any ideas so I can fix it right? Thanks Link to comment Share on other sites More sharing options...
85Sub4WD Posted January 20, 2006 Share Posted January 20, 2006 buy a cheap multimeter, and trace the wires back from the choke until you get 12V - is there anything else that stopped working about the same time? did you check the fuses? I do not know Justys well, but this is just a normal T-shooting proceedure good luck Link to comment Share on other sites More sharing options...
bob393 Posted January 20, 2006 Author Share Posted January 20, 2006 Hi Yah I did the volt meter thing and kind of got lost in the cables. The fuse is good and nothing else stoped working. I was kind of hoping that perhaps there was a temp sensor in the line that I don't know about. I will do a full blown diagnostic this weekend. Link to comment Share on other sites More sharing options...
