'03 Outback H6 - strange AC noise
I've noticed a strange hissing/whining noise coming from the passenger side of the engine when I turn on the AC.
Maybe air in a line, a pump, or...any ideas?
Thanks
Obviously, diagnosing the "whine" noise on the passenger side without being able to actually hear it is rather difficult. Any whining noise on the passenger side of my Legacy GT, however, is usually my wife. Unfortunately, that whining is "normal operation."
All kidding aside, all A/C systems "hiss" slightly when the compressor is engaged. On a Subaru, you are hearing refrigerant "hiss" thru the expansion valve (at least I think your '03 uses an expansion valve) Some other vehicle A/C systems use an orifice tube to "meter" the refrigerant thru the evaporator core under the dash. You may even hear the "hiss" continue for a moment after the A/C system is shut down, as it depressurizes.
You have checked for obvious vacuum leaks or disconnected hoses, right?
  • 2 weeks later...
