Nose Job.. My No Buck progress
hers what i got so far.. i need to do a little welding or recruit someone near buy to assist:D but its coming along with zero out of pocket.
i cut out all but the frame of the grill and inserted some cool Aluminum mesh.. and notice the notched bumper for additional cooling(welding needed)
I believe thats about 6" off the front.. turn signal guards may be useless but the fit the theme.. who knows.. may stop a rock..
i have a slightly bent up lower valance, thats coming off tomorrow to get a lil straightning.. If someone has a rx front air dam they want to let go of shoot me a pm.
more to come..
rllywgn
88 GL-10 turbo sedan
ft4wd~5spd~lsd
Looks ***************en, I am planning on doing something similar with my RX. I don't like the way the bumpers stick way out like they do.
I can help you with the welding. Maybe weld in a piece of angle iron where you cut the sheetmetal to stiffen it up a bit and keep the cooling effect?
I'm in Cornelius, OR, near Hillsboro.
That's what I was planning on doing to my 89 this summer! Cool man. I plan on doing away with the blinkers in the bumper, and trying to re-wire the side marker light(next to the headlights) to be the blinkers with an amber bulb.
I agree that the bumpers make the car look goofy.
UPDATE!
so today i yanked the passenger side fender and removed the intake silencer box thing. I then proceeded to hack the bottom of the airbox out. sounds throaty almost ricey but more throaty so i think its ok.
so now where to in the no buck build up? i guess i could spend maybe ten bucks.. any one have any suggestions on where to go next?
  • 2 months later...
so i made some more progress on the front end finally.. having a welder really helps. oh and i may have spent a few bucks on some really bright lights.. somethings you just cant get for free
this is what i started with..
then i started boxing it all in..
i still need ro make sides for the bumper.. just trying to figure out a good way to do it..
so yeah mo betta.. starting to look more and more like the rally machine i want it to be.. im dreaming of a wrx front clip... mmm...:headbang:
rllywgn
Do believe that Subaru Master Guru, Skip,, has one of his rides re-wired so that the side markers are the turn signals now. May want to do a search for that.
