Ratty2Austin Posted October 11, 2003 Share Posted October 11, 2003 so troys wagon has some major wiring problems- someone tried to splice in some weird stuff, and in the process of hotwiring the car too this person ruined all of the ignition wires.... so the car right now has a new fuel pump, and an ea71 with what looks like the standard ignition coil (my wagon has some box on top of the coil, and it says "transistor ignition" and Troy's wagon does not have that... anyways, we can get the car started for a short period of time, but then when we turn the key to the off position, the car stays running, or even if I unplug the ignition switch, it still stays ruinning! so what I want to do is wire in my own wires and switches to the ignition coil, and the fuel pump. what I am unsure about, is how the coil needs to plugged in to work, cause it looks like it is not just a power supply lead to the coil- does anyone have a schematic on how to hook this up?? thanks! Link to comment Share on other sites More sharing options...
bbbs53 Posted October 12, 2003 Share Posted October 12, 2003 Austin, what year is it? Does it have the tach dash? I have that harness. I have the book also for my Brat's. I can shoot you pics. or whatever you need. Sounds like it is a 78 or 79 or earlier, I believe, with Brats anyway, they went to the black box in '80. I have a '78 that is working and has the funky resistor on the top of the coil. Mail me, Bradd Link to comment Share on other sites More sharing options...
Ratty2Austin Posted October 12, 2003 Author Share Posted October 12, 2003 its a 1980, GL-1600 wagon (so its an ea81 body, with the ea71 engine.) but... troy got ahold of a new dash and wiring harness from a 83GL 2wd wagon, and is gonna swap the whole thing out- hopefully it will work! Link to comment Share on other sites More sharing options...
sbratw Posted April 3, 2005 Share Posted April 3, 2005 When I had the same problem of the engine running with igntion, even battery off it turned out to be the voltage regulator which is screwed to the fender beside the coil on my 78 Brat. the fuel pump is also run through the v. regulator, at 5 volts. so if you put an aftermarket fuel pump in and are running it off the 5 volt source it won't work right. run the fuel pump off a keyed source. so troys wagon has some major wiring problems- someone tried to splice in some weird stuff, and in the process of hotwiring the car too this person ruined all of the ignition wires.... so the car right now has a new fuel pump, and an ea71 with what looks like the standard ignition coil (my wagon has some box on top of the coil, and it says "transistor ignition" and Troy's wagon does not have that...anyways, we can get the car started for a short period of time, but then when we turn the key to the off position, the car stays running, or even if I unplug the ignition switch, it still stays ruinning! so what I want to do is wire in my own wires and switches to the ignition coil, and the fuel pump. what I am unsure about, is how the coil needs to plugged in to work, cause it looks like it is not just a power supply lead to the coil- does anyone have a schematic on how to hook this up?? thanks! Link to comment Share on other sites More sharing options...
