eventoday Posted January 22, 2006 Share Posted January 22, 2006 does anyone know if there is a fuse for reverse lights i lost my fuse cover panel and don't have an owners manual. needless to say i don't have any reverse lights. any other ideas other than fuses and bulbs Link to comment Share on other sites More sharing options...
Legacy777 Posted January 22, 2006 Share Posted January 22, 2006 No I don't believe there is a separate fuse, however it is tied into one of the fuse blocks. Do you notice any thing else that isn't working? Here's a diagram for the first gen legacies http://www.surrealmirage.com/subaru/files/swap/6-3_back-up_light.jpg BTW, what year and model subie do you have? Link to comment Share on other sites More sharing options...
ferret Posted January 23, 2006 Share Posted January 23, 2006 If it is a Forester 98-02, it would be Fuse 18. It also controls: AT shift lock control module Back-up light switch (MT) Cruise control main switch Cruise control module Daytime running light control module Daytime running light relay Hi-beam relay Inhibitor switch (AT) Keyless entry control module Security control module Wiper deicer relay Wiper deicer timer So of you have a 5 Speed L model, without cruise and without DRL (high beam relay in only on Forester with DRL), you might not notice anything else wrong. Link to comment Share on other sites More sharing options...
Cougar Posted January 23, 2006 Share Posted January 23, 2006 If the connection to the light is ok and the bulbs are good then I would check the switch next. They are usually mounted in the transmission case. Link to comment Share on other sites More sharing options...
