hankosolder2 Posted January 24, 2006 Share Posted January 24, 2006 Hi, I've got a '98 Legacy OB 5MT (EJ 25) and am planning on swapping in an EJ22 for reliability. I gather that the '95 legacy ej22 is the best bet for easy bolt up...due to having dual port heads and EGR. Here's my question: would a dual port ej22 block from another year work OK assuming you changed the heads to the '95 version? In particular, I'm thinking of the earlier '91-'94 dual port engines. Part two: the only reason to prefer the '95 over the '91-'94s is that the '95 has an EGR port, right? Has anyone simply defeated the EGR system and found a workaround so it doesn't trip the CEL? Thanks, Nathan Link to comment Share on other sites More sharing options...
idosubaru Posted January 24, 2006 Share Posted January 24, 2006 95 is the first year of EGR on the 2.2's but the last year of dual port. if you use 95+ then swap the exhaust header as well and you're fine. don't know about the EGR issue on older ones. Link to comment Share on other sites More sharing options...
hankosolder2 Posted January 25, 2006 Author Share Posted January 25, 2006 95 is the first year of EGR on the 2.2's but the last year of dual port. if you use 95+ then swap the exhaust header as well and you're fine. don't know about the EGR issue on older ones. Thanks! Nathan Link to comment Share on other sites More sharing options...
MTRepair Posted December 18, 2008 Share Posted December 18, 2008 One thing to think about. 95 automatics have the EGR, which you need if you want everything to talk to the 2.5 computer. 95 manuals do not have EGR. All 95's were dual port so you shouldn't have any trouble with the exhaust. 96 is when they swapped to single port. 90-94 blocks will work just fine if you have the 95 EGR heads. Tim Link to comment Share on other sites More sharing options...
screwbaru2 Posted December 18, 2008 Share Posted December 18, 2008 There is info here on drilling and tapping a non-egr head to make it egr compatible. Link to comment Share on other sites More sharing options...
