Installing a DR into a push button car. Dash lights?
It's really easy to swap half the wiring on the tranny over. The pushbutton wireing should plug into the switches on the dual range tranny, except for the neutral switch if the d/r came out of a carb car. Only the 4wd will light up, the switch for the lo range is right at the 4wd lever and there is no hookups.
Almost Hijacking post....
So can one swap dashes out between a DL and GL? Is all the wiring behind the dash standard and there are unused connectors waiting to be used?
thanks, r/ PK
I was able to do it, the only real issues that i've had were the oil pressure gauge, and i believe another gauge, but i can't remember. its pretty straight forward, but make sure to hook the vacuume line back up, as right now i only have foot warmer, which is no good when we get a frost, which luckily i wake up after it goes away.
Hmm, personally I found it an nightmare. I have put in a Tacho dash with oil pressure and volts into my DL. It took quite a while - the plugs were different.. the wire colours were different. Mine is an Australian car- maybe there is a difference with US models. There are 4 connectors on mine - all wired up differently to the DL.
thanks, r/ PK
