bmac_1277 Posted January 25, 2006 Share Posted January 25, 2006 Hi I have a 91 awd legacy wagon. Im replacing the front passanger side spindle. Can anyone tell me how to remove the abs sensor on the back of the spindle ? thanks bmac_1277 Link to comment Share on other sites More sharing options...
Legacy777 Posted January 25, 2006 Share Posted January 25, 2006 There should be a bolt that holds it into place. However with time they get rusted in there. So you may need to squirt a lot of penetrating oil in there and try to gently tap it out. Link to comment Share on other sites More sharing options...
bmac_1277 Posted January 25, 2006 Author Share Posted January 25, 2006 There should be a bolt that holds it into place. However with time they get rusted in there. So you may need to squirt a lot of penetrating oil in there and try to gently tap it out. thanks legacy777 those buggers were in so snug I was worried id ruin the seal on the sensor. so I took the new spindle with an abs already on unplugged the old wiring thru the firewall and hooked up the new connection from the new spindle. getting access to the wiring harness in the engine copartment was no easy feat. after removing all kinds of brackets by the abs system i accessed the harness. Link to comment Share on other sites More sharing options...
bmac_1277 Posted January 25, 2006 Author Share Posted January 25, 2006 There should be a bolt that holds it into place. However with time they get rusted in there. So you may need to squirt a lot of penetrating oil in there and try to gently tap it out. one other question.... where do you access the abs wiring connector for the passenger side rear wheel ? my fear that it will be inside the car under the carpet running up to the front. Link to comment Share on other sites More sharing options...
Danbob99 Posted January 26, 2006 Share Posted January 26, 2006 Under the fold up part of the rear seat(that you sit on) i believe. Link to comment Share on other sites More sharing options...
bmac_1277 Posted January 26, 2006 Author Share Posted January 26, 2006 Under the fold up part of the rear seat(that you sit on) i believe. thanks id be tearing up carpet Link to comment Share on other sites More sharing options...
Legacy777 Posted January 27, 2006 Share Posted January 27, 2006 Yeah....if you follow the brake lines, and see where they go into the cabin, there is another rubber grommet that has the ABS sensor wiring going to it. Link to comment Share on other sites More sharing options...
