demsgudeatin Posted January 25, 2006 Share Posted January 25, 2006 Some low-life sack of s__t took a concrete block and broke the driver window to get inside my '03 WRX. In doing so they beat the crap out of the top portion of the door. So my question is since paint is so hard to match should I fix the door or try to find a driver's door for a sonic yellow wagon? Like they grow on trees, right? Quote Link to comment Share on other sites More sharing options...
Legacy777 Posted January 25, 2006 Share Posted January 25, 2006 It'd probably be cheaper to find a used door, even if it is the wrong color because the body work to try and fix the door would probably be more or similar....and I'm not sure the results would be as good. You may want to post in the texas forums on nasioc http://forums.nasioc.com/forums Quote Link to comment Share on other sites More sharing options...
WagonsOnly Posted January 26, 2006 Share Posted January 26, 2006 A sedan door should be the same (and they also came in Sonic Yellow)...sorry to hear about that Quote Link to comment Share on other sites More sharing options...
