Gr8subi Posted January 27, 2006 Share Posted January 27, 2006 I've got a 97' OBW, and my problem is no reading on the temp gauge. engine not running hot its just not picking up the temp reading at all. Reading my Haynes manual but still not sure where to begin. Is it a relay thing or electronic control module- no clear diagram on where that is even located. any tips or advice? Link to comment Share on other sites More sharing options...
blitz Posted January 28, 2006 Share Posted January 28, 2006 Four basic possibilities: 1. Defective sender. 2. Defective meter. 3. Blown fuse. 4. Bad connection. You might want to spring for a factory manual. Link to comment Share on other sites More sharing options...
Subie Gal Posted January 28, 2006 Share Posted January 28, 2006 you more than likely need a new coolant temp sensor they dont last "forever" although they typically last a good long time. Jamie Link to comment Share on other sites More sharing options...
edrach Posted January 28, 2006 Share Posted January 28, 2006 EJ22 engine has two coolant sensors; one for the ECU and one for the temp guage. Make sure you get the correct one. Link to comment Share on other sites More sharing options...
gbrand Posted January 28, 2006 Share Posted January 28, 2006 If like my 91 coolant sensor located on pass side under intake manifold, a pain to get to. I would unplug the connector, or if lucky find it has worked loose, and then try subtituting an appropriate resistor in place of the sensor and see if the guage moves. That way if the sensor was good, and the guage is bad(or wire is broken between the two) you have not wasted time to remove an item that is a PIA to get in and out. Link to comment Share on other sites More sharing options...
Gr8subi Posted January 29, 2006 Author Share Posted January 29, 2006 thanks for the tips, I'll jump in and take a look in the morning and see what I can find. think I will start w/the easy and work my way up......... Link to comment Share on other sites More sharing options...
