Subadud Posted January 28, 2006 Share Posted January 28, 2006 Please read about it in the NASIOC forums at http://forums.nasioc.com/forums/showthread.php?p=12473892#post12473892 I need any advice that you can offer. Link to comment Share on other sites More sharing options...
nipper Posted January 28, 2006 Share Posted January 28, 2006 Does the car act the same if it is shifted manually? nipper Link to comment Share on other sites More sharing options...
Subadud Posted January 28, 2006 Author Share Posted January 28, 2006 Dan, Put it on D1 and D2 and it seemed to do the same thing. Why do you ask? Link to comment Share on other sites More sharing options...
nipper Posted January 28, 2006 Share Posted January 28, 2006 Just ruling out a computer problem. Manually shifting the car overrides the computer. Have you checked the tranny fluid level and condition? Link to comment Share on other sites More sharing options...
Subadud Posted January 29, 2006 Author Share Posted January 29, 2006 I myself did not check the tranny fluid but the dealership did. Basically I was told that when the technician checked the fluids, he found that the tranny was low and the Gearbox was overfilled so he drained the Gearbox to the correct level and filled the tranny fluid to the correct level. After that he took the car out for a drive and it was driving fine. Once he got back to the shop, the fluids levels were checked again and he found the tranny fluid level was low and the differential fluid was high leading to the conclusion that the seal between the diff and trans was bad and the fluids were mixing. BTW I very much appreciate your answers since I am quite worried and at this point need as much advice I can get on what to do next. Link to comment Share on other sites More sharing options...
Subadud Posted January 29, 2006 Author Share Posted January 29, 2006 I recommend everyone with these issues to report the problem at the nhtsa Office of Defects website at: http://www-odi.nhtsa.dot.gov/cars/problems/complain/ If you think going down the highway at 75mph and the HG blows or tranny goes is not a safety issue, think again. They do take complaints seriously. Link to comment Share on other sites More sharing options...
