Lifting up the rear end a little
what kinda vehicle exactly? I have a brat and I hear it can't (except maxing the adjustments on the struts) but I hear that some of the wagons and maybe the hatches too have separate top mounts for the struts that would give you more in the back
Like Brats and Wagons, there should be a rear torsion bar bolt to adjust. Pop the rear seat up or it may be in the hatch area, remove rubber plug to expose the bolt in the center of the vehicle, above the rear torsion bar. It's best to jack the car up to take the load off while you adjust. Good luck. r/ PK.
