is there any repair info on this board?
I have a 95 legacy....I want to replace the timing belts...any info on this website that I can print to do the job?
I am well versed on doing the Loyale type (even made my own adjusting tool to attach to my torque wrench) but not the legacy
What else (besides the camshaft seals) should be replaced?w waterpump?
the repair info associated with this board is at:
http://www.usmb.net/repair/
other resources include:
http://www.endwrench.com/pages/home.html
and
http://techinfo.subaru.com
as for what to do, it somewhat depends on mileage. usually water pump is advised, because it is cheap. tensioners can usually wait until the 2nd belt change, seals are usually recommended (the crank seal as well).
