moshem74 Posted January 30, 2006 Share Posted January 30, 2006 can someone tell me if i can put wheel spicers on subaru loyale without changing the nuts of the wheels? those are my wheel's in the pic (my car) : i want to add spicers , what do i need to do and which kind of spicers do i need , i'm willing to order from ebay, if you can give me a link for what i need , it will be greate. thank you all. moshe. Quote Link to comment Share on other sites More sharing options...
rllywgn Posted January 30, 2006 Share Posted January 30, 2006 you can change them, but finding them is the hard part. you can add a spacer to almost any car as long as you dont go to extreme by not leaving enough stub to get the bolt over.. what effect are you going for? tllywgn Quote Link to comment Share on other sites More sharing options...
Dr. RX Posted January 30, 2006 Share Posted January 30, 2006 OK, you mean spacer, a spicer is the cross shape piece of the universal joints on a driveline. On wheel spacers you should have at least some threads showing, two would be safe, more is better. Most spacers require either longer studs or bolts. Quote Link to comment Share on other sites More sharing options...
northguy Posted January 30, 2006 Share Posted January 30, 2006 Might I suggest cumin or paprika? Quote Link to comment Share on other sites More sharing options...
moshem74 Posted January 30, 2006 Author Share Posted January 30, 2006 hi wheel spacers where can i find either longer studs or bolts.? Quote Link to comment Share on other sites More sharing options...
Dr. RX Posted January 30, 2006 Share Posted January 30, 2006 Why don't you do a Google search for 'wheel spacers' and see what comes up, usually any place that has spacers for a Subaru should have longer studs too. Quote Link to comment Share on other sites More sharing options...
FlyB0y Posted January 31, 2006 Share Posted January 31, 2006 there are some toyota lug bolts that are about 3/8 - 1/2" longer, but good luck finding spacers for 4 x 140mm bolt pattern (at least in the US) Quote Link to comment Share on other sites More sharing options...
BlueSteel Posted January 31, 2006 Share Posted January 31, 2006 heres a site that do em... not too cheap tho http://www.truckn-store.com/product.asp?pg=2&ID=93730&returnURL=%2Fproduct%2Easp%3Fsource%3D%26ID%3D93730%26returnURL%3D%252Fproduct%255Flist%252Easp%253Fid%253D1482 oh and they do adapters too http://www.truckn-store.com/product.asp?pg=3&ID=93731&returnURL=%2Fproduct%2Easp%3Fpg%3D4%26ID%3D93731%26returnURL%3D%252Fproduct%252Easp%253Fpg%253D3%2526ID%253D93731%2526returnURL%253D%25252Fproduct%25252Easp%25253Fpg%25253D2%252526ID%25253D93731%252526returnURL%25253D%2525252Fproduct%2525252Easp%2525253FreturnURL%2525253Ddefault%2525252Easp%25252526ID%2525253D93731 havent used them, but they look the goods Quote Link to comment Share on other sites More sharing options...
hatchsub Posted January 31, 2006 Share Posted January 31, 2006 I know u want spacers for those rims but i gotta ask why. That car looks great the way it is. Those rims are already out to the edge without hanging outside the bodylines. Quote Link to comment Share on other sites More sharing options...
samo Posted January 31, 2006 Share Posted January 31, 2006 OK, you mean spacer, a spicer is the cross shape piece of the universal joints on a driveline. Haha... that's the first thing I thought of when I read the post. I was thinking "how on earth would you add a Spicer joint to a wheel?" But then it made sense. You may not have to change the lug nuts themselves, but the studs may have to be changed depending on the width of the spacer. When I put spacers on my previous shop's Audi, we needed new lug bolts on the rear where we added 15MM spacers. The fronts which got only 5MM didn't need them. It'll all just depend on how wide you go. Quote Link to comment Share on other sites More sharing options...
FlyB0y Posted January 31, 2006 Share Posted January 31, 2006 I know u want spacers for those rims but i gotta ask why. That car looks great the way it is. Those rims are already out to the edge without hanging outside the bodylines. I gotta agree with hatchsub ... also, remember that any time you use a spacer or even just a larger off-set wheel you run the risk of destroying wheel bearings ... I was told that 1/2" was the max I should ever go with spacers, and then my local metal fab guy talked me into just 3/8" ... I now have a different off-set wheels (converted to 6 lug) but many have used the off-set with the same tires I have now with good results ... so just be carefull ... if you go too far you will have more trouble than you bargined for ... just my two cents ... Quote Link to comment Share on other sites More sharing options...
