95 legacy oil pan replacement
can anyone tell me is it possible to replace the oil pan on a 95 legacy without lifting the engine to access the rear bolts to the oil pan ?
Bill
I did it with my 96 Brighton. But I had to enlarge (file and dremel) a couple of holes thru which you can access the rear bolts. It was so difficult to place the bolts that I think I cross threaded two of them but succeeded in reaching the proper torque anyway. If I had to do it again, I would lift the engine.
