JordanR693 Posted February 1, 2006 Share Posted February 1, 2006 Ok i was driving down the interstate all was good then my car started bucking a little and and acting like it was having a fuel problem. Im not sure if this has happened to any of you before but you think its the pump? I have a feeling im going to be dropping the tank = \. A guy on the new gen forum told me that it might be the fuel filter because the same thing happened to him and it fixed it? If so i probable want to try that since its cheaper and i need to get my ride back on the road asap. Just got my KYB Forester Struts today btw = ) hoping to put them on the weekend. Oh yes and where is the fuel filter located in this thing? How much of a job do you think it is going to be for me to do it? I wasnt sure where it was i figured it might be part of the assembly on the tank somewhere but i could be wrong. I couldnt find a manual on it and 94 Impreza L is new to me all i know before this is Rx7. Just happened today btw Quote Link to comment Share on other sites More sharing options...
NoahDL88 Posted February 1, 2006 Share Posted February 1, 2006 What kind of car? fuel injected or carby? what year? You might try this in the new gen forum, as this "offroad forum" is for offroad problems, and the new gen is for drivability problems Quote Link to comment Share on other sites More sharing options...
JordanR693 Posted February 1, 2006 Author Share Posted February 1, 2006 94 Impreza L , Fuel Inj Quote Link to comment Share on other sites More sharing options...
JordanR693 Posted February 1, 2006 Author Share Posted February 1, 2006 Odd it starts up and acts like it runs fine now but i know it will do it again because it started to kinda do it the other day. I guess i will try the fuel filter Quote Link to comment Share on other sites More sharing options...
jeffast Posted February 1, 2006 Share Posted February 1, 2006 wrong forum this is the old gen forum pre 90's you want the newer gen forum Quote Link to comment Share on other sites More sharing options...
[HTi]Johnson Posted February 1, 2006 Share Posted February 1, 2006 http://www.ultimatesubaru.org/forum/forumdisplay.php?f=3 here's the link to the new gens, we're not kicking you out or anything, just showing you the best place to get help with your car. Quote Link to comment Share on other sites More sharing options...
Jack in Norfolk Posted February 1, 2006 Share Posted February 1, 2006 Ok i was driving down the interstate all was good then my car started bucking a little and and acting like it was having a fuel problem. Im not sure if this has happened to any of you before but you think its the pump? I have a feeling im going to be dropping the tank = \. A guy on the new gen forum told me that it might be the fuel filter because the same thing happened to him and it fixed it? If so i probable want to try that since its cheaper and i need to get my ride back on the road asap. Just got my KYB Forester Struts today btw = ) hoping to put them on the weekend. Oh yes and where is the fuel filter located in this thing? How much of a job do you think it is going to be for me to do it? I wasnt sure where it was i figured it might be part of the assembly on the tank somewhere but i could be wrong. I couldnt find a manual on it and 94 Impreza L is new to me all i know before this is Rx7. Just happened today btw Not to be a smart@ss, but I don't suppose you checked to see if the car had fuel did you? Quote Link to comment Share on other sites More sharing options...
JordanR693 Posted February 1, 2006 Author Share Posted February 1, 2006 Yes the car has gas =) lol. I dont blame you people do it all the time Haha Quote Link to comment Share on other sites More sharing options...
4x4_Welder Posted February 2, 2006 Share Posted February 2, 2006 I'm more familiar with trucks, but the principles are the same: Check your fuel pressure. Autzone has rental fuel pressure testers. Not sure on the specifics, but idle fuel pressure -should- be in the range of 35-45psi, a little higher with the throttle open or the vacuum line off the fuel pressure regulator. If the pressure is low, try changing the fuel filter. IIRC, it's right near the tank on that car. If the pressure reading goes up, and the stumble/dying problem goes away, that was it. If the pressure doesn't change, then it very well may be the pump. Quote Link to comment Share on other sites More sharing options...
85Sub4WD Posted February 2, 2006 Share Posted February 2, 2006 how are the plugs/wires/coil pack? my mom's van did the same thing, and it turned out to be bad plugs/wires good luck Quote Link to comment Share on other sites More sharing options...
