[HTi]Johnson Posted February 1, 2006 Share Posted February 1, 2006 Hello all. I was wondering if there is a difference in the front harness between years of EJs. I don't mean Ej22 is different than ej25...i mean did they change the harness in the years within the EJ22? I'm talking about the front harness that is required for conversion/transplant into an EA series. Thanks all for your time. Justin. Link to comment Share on other sites More sharing options...
WJM Posted February 1, 2006 Share Posted February 1, 2006 well....................... I bet so. I'll look at the FSM's when I get time. Link to comment Share on other sites More sharing options...
[HTi]Johnson Posted February 1, 2006 Author Share Posted February 1, 2006 Thanks Will. By the sound of it, with your new RX project, it doesn't sound like you have much time. Link to comment Share on other sites More sharing options...
NoahDL88 Posted February 1, 2006 Share Posted February 1, 2006 The EJ harness, 90-94 is basically the same thoughout, but the colors of the wires have changed and there is a different setup with the diode, and some of the relays. Link to comment Share on other sites More sharing options...
Legacy777 Posted February 1, 2006 Share Posted February 1, 2006 Yes there is differences. For example, the engine electrical harness for the 90-91 n/a legacies use 3 square connectors. The 92-94 n/a legacies use 2 square connectors, while the 91-94 turbo legacies use two square connectors and one round connector. Link to comment Share on other sites More sharing options...
ballitch Posted February 3, 2006 Share Posted February 3, 2006 yes, many differences, DO NOT use somnones wiring colors for any given harness, chances are its NOT the same and will not work for you. your just going to have to buy a haynes or chiltons manual with the wiring diagrams and figure out which harness you have and mark all the wires form the ECU, and trace them to whereever they end. long and tedious, but well worth it. ~Josh~ Link to comment Share on other sites More sharing options...
monstaru Posted February 3, 2006 Share Posted February 3, 2006 not only is the colormatch a ***************,if you get one from a later model the harness comes out on the back of the engine instead of the drivers side.(which going into an ea-81 is not good)ea-82 works out well. Link to comment Share on other sites More sharing options...
7point62fmj Posted February 6, 2006 Share Posted February 6, 2006 so.. not to hi-jack but if I wanted to use a 97 motor with a 90-94 ecu.. could I? the reason I ask is because I can get a ej22 but it is a 97 and I dont want to mess with the whole speed sensor deal. So I would like to use the other older ecu. Link to comment Share on other sites More sharing options...
ballitch Posted February 7, 2006 Share Posted February 7, 2006 thats what i did, i used 96 impreza motor with 1990 legacy wiring and ecu. had to swap throttle body to a 4-wire throttle pos. sensor, and had to plug off EGR on intake manifold. ~Josh~ Link to comment Share on other sites More sharing options...
Legacy777 Posted February 7, 2006 Share Posted February 7, 2006 As josh mentioned, you have to use the engine wiring harness from the 90-94 legacy so the engine connectors hook up. Link to comment Share on other sites More sharing options...
