4x4_Welder Posted February 2, 2006 Share Posted February 2, 2006 Got the car running great, it finally idles down, stopped burning oil, all the electrical has come back to life, then I comeout to a 6" green puddle under the car. The right hand intake leg has started leaking coolant at the base gasket. It doesn't seem to be burning any yet, just leaking to the outside. So, I am now taking all bets, how many of the six bolts will break? Link to comment Share on other sites More sharing options...
jeffast Posted February 2, 2006 Share Posted February 2, 2006 the bottom2 Link to comment Share on other sites More sharing options...
rllywgn Posted February 2, 2006 Share Posted February 2, 2006 im guessing 2 will break.. thats the least ive had break when removing the manifold. 5 out of 6 is the best (or worst) ive managed to have. good luck! rllywgn Link to comment Share on other sites More sharing options...
subiemech85 Posted February 2, 2006 Share Posted February 2, 2006 I had good luck, no broken, using a air impact to gently remove the bolts the breaker bar method broke 3 Link to comment Share on other sites More sharing options...
[HTi]Johnson Posted February 2, 2006 Share Posted February 2, 2006 Lol I broke 1 the other day...good thing I have about 3/8" sticking out. Link to comment Share on other sites More sharing options...
Caboobaroo Posted February 2, 2006 Share Posted February 2, 2006 a great thing to do when you go to put the intake back on it get new bolts or use a wire wheel on the current ones. I would go with new myself since the originals probably already have some rust eating away at them. Then get a bottle of antisieze, the stuff that EVERYONE should be using on their sparkplugs, and put a little on the threads. It will make you life sooooo much easier if you have to do this down the road... or the next Sube nut that gets ahold of your car. Link to comment Share on other sites More sharing options...
GeneralDisorder Posted February 2, 2006 Share Posted February 2, 2006 And use OEM gaskets for the manifold ONLY. They are a lot better. Otherwise you'll probably be doing them again soon. GD Link to comment Share on other sites More sharing options...
Alex C Posted February 2, 2006 Share Posted February 2, 2006 Antiseize is great, but DONT use the silver on spark plugs. Use the Copper on the spark plugs, and the silver for everything else. We learned the hard way at the shop that the silver doesnt give a good ground for the spark plugs. We bought a round of copper for all the techs, and we stopped having misfire problems. Alex (at D&S harley) Link to comment Share on other sites More sharing options...
Flowmastered87GL Posted February 2, 2006 Share Posted February 2, 2006 Worst... 3 broke. Best... 0 broke Link to comment Share on other sites More sharing options...
GLCraig Posted February 2, 2006 Share Posted February 2, 2006 Flowmastered87GL said: Worst... 3 broke. Best... 0 broke I average 1 per 15 Engines when I was scrappingout EAxxs for a living. Link to comment Share on other sites More sharing options...
Subi81 Posted February 2, 2006 Share Posted February 2, 2006 Alex C thanks for that tip, I have been using the silver and experiancing missfireing. I will have to look into that next time I do my plugs. I agree with the antiseize use it on any fastener connected to the aluminum block Link to comment Share on other sites More sharing options...
GeneralDisorder Posted February 3, 2006 Share Posted February 3, 2006 Only time I've borked one was putting it back in after replaceing the gasket..... too tight. Oops! GD Link to comment Share on other sites More sharing options...
monstaru Posted February 3, 2006 Share Posted February 3, 2006 i bet none.......if you spray with some type of liquid wrench,pb blaster or whatever that other stuff is called. Link to comment Share on other sites More sharing options...
4x4_Welder Posted February 3, 2006 Author Share Posted February 3, 2006 What about doing it with the engine semi-warm? When I broke the pivot ball off, I welded a washer onto it, and it came out with finger pressure. As far as anti-seize, for something like this I use Magnalube G. It's a teflon based lube, I have used it for tons of stuff, including exhaust/intake bolts on my old 300-6, and they just spin out, no rust. Link to comment Share on other sites More sharing options...
