kingbobdole Posted February 2, 2006 Share Posted February 2, 2006 This is with 2 months of use, but I'm pretty sure that they went this way in about 3 days..... this was very loud... Now with OEM, its quite again... and I really didnt save anything going NAPA either:banghead: Quote Link to comment Share on other sites More sharing options...
Phizinza Posted February 2, 2006 Share Posted February 2, 2006 I get the same problem with the cheap gaskets I get locally. Maybe I should find some good Subaru ones... __________ little brat http://www.offroadingsubarus.com Quote Link to comment Share on other sites More sharing options...
86subaru Posted February 2, 2006 Share Posted February 2, 2006 carquest has real nice thick ones, Quote Link to comment Share on other sites More sharing options...
Subaru Jim Maple Ridge Posted February 2, 2006 Share Posted February 2, 2006 The quality of the gaskets are not nearly as important as the bolt holes or studs keeping the surfaces together. A gasket usually blows out or leaks because nuts loosen off or the threads in the head are in bad shape. Quote Link to comment Share on other sites More sharing options...
85Sub4WD Posted February 2, 2006 Share Posted February 2, 2006 Actually, if you use the EA81 style NAPA gaskets, they work REALLY well - and for that matter, I used a pair of OEM Subaru gaskets and had the EXACT same problem - torquing the exhaust studs enought is CRITICAL to prevent gasket failure Quote Link to comment Share on other sites More sharing options...
idosubaru Posted February 2, 2006 Share Posted February 2, 2006 agreed on the torquing aspect. i've had subaru gaskets do the same thing if the exhaust isn't bolted up tight (like on something i fabricated). but on good, tight connections i've reused the old exhaust gaskets before with no problems. i've reused the exhaust manifold gaskets before that looked terrible but didn't leak. but i've also installed new gaskets with stripped out head studs that leaked in well under a year. seems any small leakage will cause the gasket to degrade quick. heat i guess? Quote Link to comment Share on other sites More sharing options...
Mr Fishums Posted February 2, 2006 Share Posted February 2, 2006 Heres a question while on the topic of exhaust gaskets. I removed my ASB plates from the block, because I no longer use the 3/4 pipe that comes off of both sides with my custom carb job. The only issues is, what kind of gasket/way of mounting these headers should I go about instead? This is an EA-81 block btw. Any ideas? suggestions? I was thinking of just flaring some pipe and using the stock oval two stud bracer, and gasket. then just tighten them right down on the block.... It's just such soft metal I don't know if I can tighten it enough to stop it from leaking. Quote Link to comment Share on other sites More sharing options...
blownbimer Posted February 2, 2006 Share Posted February 2, 2006 So your saying torque it till you fart, then back it off half a turn is not the proper spec for exhaust bolts? Hehe...Glad you got your cesnna fixed phil! Thanks Erik Quote Link to comment Share on other sites More sharing options...
hatchsub Posted February 2, 2006 Share Posted February 2, 2006 Um maybe a dumb question but are those exhaust manifold gaskets or just gaskets down the exhaust somewhere? Im hoping that mine wont look like that once i get my exhaust leak fixed. My care is loud as all hell right now because both..count em both! exhaust manifold gaskets blew out. Good stuff. Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted February 2, 2006 Share Posted February 2, 2006 Those are manifold gaskets, but definately crappy ones. The good ones (such as the Fel-Pro's) are multi-layer metal and are difficult to bend by hand. The cheap ones are kinda floppy. Fel-Pro's are availible on a lot of web sites for not a lot. GD Quote Link to comment Share on other sites More sharing options...
torxxx Posted February 2, 2006 Share Posted February 2, 2006 I used a gasket from carquest for the exhaust headers. part number is 12284 they are the same size as subaru oem gaskets but they are about 2 or 3 times as thick with metal on both sides and then fiber or something in the middle. I've had NO problems with them blowing out Quote Link to comment Share on other sites More sharing options...
jeffast Posted February 3, 2006 Share Posted February 3, 2006 i'm pretty sure it was something about the way phil drives nah those gaskets look horrable how could you send me to napa why phil why Quote Link to comment Share on other sites More sharing options...
Meeky Moose Posted February 3, 2006 Share Posted February 3, 2006 just a helpful tip for all, do not buy the regular exhaust gaskets for a carbed or spfi engine aftermarket, they usually come looking like a piece of paper with a metal ring in the center.. they always blow out.. instead get gaskets for say a 90 loyale rs turbo.. they are made of the same material as like a headgasket.. all metal/lead fiber.. they fit the same and don't blow out.. and they are like $9 from advance for a set.. just my input Quote Link to comment Share on other sites More sharing options...
torxxx Posted February 3, 2006 Share Posted February 3, 2006 yeah thats the ones that I get from carquest. They told me they fit one year of soobs but they didnt know which one. #12284 at Carquest . Quote Link to comment Share on other sites More sharing options...
nicky nighteyes Posted February 4, 2006 Share Posted February 4, 2006 torxx, just called carquest, they said that wasnt one of their part #'s, said it should have some letters or something. Could you double check that #? i really need to replace my gaskets. yeah thats the ones that I get from carquest. They told me they fit one year of soobs but they didnt know which one. #12284 at Carquest . Quote Link to comment Share on other sites More sharing options...
