dunkinman Posted February 2, 2006 Share Posted February 2, 2006 hi there, I JUST BOUGHT A 1996 OUTBACK WAGON IT DIDNT COME WITH A OWNERS MANUAL. I NOTICE THAT ON THE SHIFTER IT HAS PARK-REVERSE-NUETRAL-DRIVE-3-2-1 MY QUESTION IS WHEN DRIVING AROUND TOWN DO I DRIVE IN D OR 3. DOES ANYBODY HAVE ANY INFO ON THIS SUBARU THAT I SHOULD LOOK AT OR HAVE CHECKED OUT. I DO SMELL A FAINT ANTIFREEZE WHEN I GO BY CAR AFTER DRIVING BUT WHEN I LOOK UNDER THE HOOD I CANT FIND ANY SIGNS OF A LEAK IS THIS NORMAL. IM JUST LOOKING FOR ANY INFO ON KNOWN PROMBLEMS WITH THIS MODEL. IT HAS A 2.5 LITER - AUTOMATIC TRANSMISSION - 166,000 miles SINCERELY YOURS NEWBE SUBE Link to comment Share on other sites More sharing options...
calebz Posted February 2, 2006 Share Posted February 2, 2006 Moving to new gen. PS, try turning the caps lock off. Not nice to yell at everyone with your introductory post Link to comment Share on other sites More sharing options...
dunkinman Posted February 2, 2006 Author Share Posted February 2, 2006 Moving to new gen. PS, try turning the caps lock off. Not nice to yell at everyone with your introductory post hi whats up yeah thanks for the info on the cap locks dunkinman Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted February 2, 2006 Share Posted February 2, 2006 hi there, I JUST BOUGHT A 1996 OUTBACK WAGON IT DIDNT COME WITH A OWNERS MANUAL. I NOTICE THAT ON THE SHIFTER IT HAS PARK-REVERSE-NUETRAL-DRIVE-3-2-1 MY QUESTION IS WHEN DRIVING AROUND TOWN DO I DRIVE IN D OR 3. DOES ANYBODY HAVE ANY INFO ON THIS SUBARU THAT I SHOULD LOOK AT OR HAVE CHECKED OUT. I DO SMELL A FAINT ANTIFREEZE WHEN I GO BY CAR AFTER DRIVING BUT WHEN I LOOK UNDER THE HOOD I CANT FIND ANY SIGNS OF A LEAK IS THIS NORMAL. IM JUST LOOKING FOR ANY INFO ON KNOWN PROMBLEMS WITH THIS MODEL. IT HAS A 2.5 LITER - AUTOMATIC TRANSMISSION - 166,000 miles SINCERELY YOURS NEWBE SUBE use 'D' unless you have a need to lock in a lower gear or other unusual circumstances. You could always order a manual - try Jamie at www.subarugenuineparts.com also, look around at www.cars101.com Definetly investigate the coolant smell. Could be a simple as a bad radiator cap. welcome to the boards! Link to comment Share on other sites More sharing options...
idosubaru Posted February 2, 2006 Share Posted February 2, 2006 use "D". 2.5's have headgasket issues, the "search" function is your friend. practice with it and it'll give you lots of help. you'll see lots of headgasket issues with the 2.5 liter of that vintage. of course hoses, leaks, radiator caps should be checked first. does the temp gauge hold steady or move around? have you popped the hood and checked for coolant loss or to see where the smell/fluid is coming from? first thing you should do is put a couple gallons of antifree in the car, just in case. best to have some for back up than blow the motor if it starts to overheat. Link to comment Share on other sites More sharing options...
nipper Posted February 2, 2006 Share Posted February 2, 2006 Welcome If your putting AF in the car use the premix. The AF smell, check all the easy stuff first. Usually the 2.5L blows a headgasket internally. My 97 OBW does the same thing your does, i just keep an eye on it, as its so minor i cant seem to find the source, and just keep a close eye on the temp gauge. nipper Link to comment Share on other sites More sharing options...
subastic Posted February 2, 2006 Share Posted February 2, 2006 hi there, I JUST BOUGHT A 1996 OUTBACK WAGON IT DIDNT COME WITH A OWNERS MANUAL. I NOTICE THAT ON THE SHIFTER IT HAS PARK-REVERSE-NUETRAL-DRIVE-3-2-1 MY QUESTION IS WHEN DRIVING AROUND TOWN DO I DRIVE IN D OR 3. DOES ANYBODY HAVE ANY INFO ON THIS SUBARU THAT I SHOULD LOOK AT OR HAVE CHECKED OUT. I DO SMELL A FAINT ANTIFREEZE WHEN I GO BY CAR AFTER DRIVING BUT WHEN I LOOK UNDER THE HOOD I CANT FIND ANY SIGNS OF A LEAK IS THIS NORMAL. IM JUST LOOKING FOR ANY INFO ON KNOWN PROMBLEMS WITH THIS MODEL. IT HAS A 2.5 LITER - AUTOMATIC TRANSMISSION - 166,000 miles SINCERELY YOURS NEWBE SUBE My 97 obw had a slight temperature problem, really just a fluctuation in the temp gauge upon strenuous driving, i.e. start and stop, up hills, etc. There are usually just three reasons for this: 1. The worst case: head gasket is blown 2. Not as bad: the coolant clumps in the radiator, solved by replacing the radiator and coolant 3. The thermostat is bad I replaced the radiator and hoses and the temp sender and all is well. You know its the head gasket if the coolant smells like exhaust, just open the radiator cap when it is COOL, and smell the coolant. Link to comment Share on other sites More sharing options...
