Where's my two gallons?
Ok I have a strange gas tank compacity issue. The manual and the board says the compacity on my 92 loyale is 16 gallons. But I can't seem to get more than 14 gallons in, even when I sputter and chug to the gas station, as i did this morning.
The orange 'low fuel' light comes on and I can fill up a little over 12 gallons, so that figures right. My mpg is good at 28, and I get a little over 400 miles to a tank. When the tank is 'full' the gauge needle barely reaches the top mark.
So I'm wondering what's taking up the space of that extra 2 gallons? It's not a major issue, or a problem, just something I wonder about at the pump.
pat
I ran out as much as I could this morning, sputtering and chugging to the gas station, wasen't perty! Even after i filled up it took some hard cranking to get it started again, I took that as a sign that the tank was empty.
On another note, what makes the gas pump automatically stop, is it something in the neck of the gas tank, or in the pump handle? Maybe it's never been full because of a faulty 'full' signal when the pump stops. I don't keep trying to get that even .50 or .00, I say when it clicks off it's full!
You can normally get quite a bit more in if you fill untill it clicks off at half speed or so, after it has initially clicked off.
True, when the pump handle clicks off that means your tank is full. There is a sensor in the handle that shuts off the flow when just a little backwash comes up the filler pipe. Try not holding the nozzle all the way in the filler pipe and use the half speed when it starts getting full. Either way tho, the gauge should be reading correcly when the tank is filled normally.
pat
hmmmmmm..... you take it to mean you are empty, yet you made it to the gas station in fits of stalling...... maybe a vaporlock from sooooo little fuel, just a thought :) or maybe tired fuel guage....
It Is Not Full Until You Can Not Squeeze In Any More Gas, And The Level Is Above The Flapper Door
HA HA
you're in colorado, is it hilly where you live? you might be in the "chugging" region on grade but fine were you on flat ground...meaning you still have some fuel in there, but it's slopping around and not always accessible to the fuel pump like those floridians.
i get 15 gallons in mine, but i gotta run way dry to get to that point. after the light comes on i can get about 70 miles more (2.7 gallons are supposed to be left when the light comes on) on flat ground.
From what I have heard on older cars (older then about 95) you can fill the tanks right up to the flapper which I do... just throattle the pump nozzle by hand, ... on newer cars you shouldn't do that... I have no Idea why, just heard that on a car show, something about revents that get flooded and no longer work and it messes with the sensors.... blaa..blaa..bla..
also: "Where's my two gallons?" you wouldn't happen to be punning
the paper-boy from the movie, "Better off dead."?
Here's one for ya. As some of you may remember, I was having massive fuel delivery problems getting my sons' hatch ('86) down the road. One of the many things I found, was that when I had dropped the tank to clean it, when I reinstalled it, I slightly kinked the filler neck vent line. This would prevent air from escaping as the tank filled, causing the filler neck to back up with fuel. Which of course causes the gas pump to shut off. You might want to check that vent line. I don't know why it would plug if you've never dropped the tank, but just one more thing to look for....
Good luck!
NV
  • 2 weeks later...
