dunkinman Posted February 5, 2006 Share Posted February 5, 2006 Whats up every one, Does anyone know what the gas milage should be on a 1996 subuaru outback wagon - automatic - 2.5 - Looks like im getting 15 miles to the gallon i thought i could get more than that. dunkinman Link to comment Share on other sites More sharing options...
dxrflyboy Posted February 5, 2006 Share Posted February 5, 2006 Whats up every one, Does anyone know what the gas milage should be on a 1996 subuaru outback wagon - automatic - 2.5 - Looks like im getting 15 miles to the gallon i thought i could get more than that. dunkinman How long have you had the car? How are you measuring your gas mileage? What are your driving conditions? How does the car run? Is your check engine light coming on? To answer your question, yes, you should expect better than 15 mpg but exactly how much better depends on how you use it. Link to comment Share on other sites More sharing options...
dunkinman Posted February 5, 2006 Author Share Posted February 5, 2006 How long have you had the car? How are you measuring your gas mileage? What are your driving conditions? How does the car run? Is your check engine light coming on? To answer your question, yes, you should expect better than 15 mpg but exactly how much better depends on how you use it. hi there , i just bought it from the dealer runs great no engine light on but when i first drove it there was a check engine light on the dealer said they found a misfire on it replaced wires and spark plugs.and told me it was fine. i drive around town alot but i baby it. well when i first pick it up from deealer it was empty low fuel light was on so i filled it up with super it took 13.5 gallons now im under 1/4 tank and ive gone 154 miles. Link to comment Share on other sites More sharing options...
hawksoob Posted February 5, 2006 Share Posted February 5, 2006 With 1/4 tank showing you actually may have more like 1/3 or more remaining. You really can't go by what the gas gauge says. To get your mileage more accurately: 1. Fill up 2. Zero out trip odometer 3. Drive around for a week or so 4. Fill up 5. Divide the number of miles on the trip odometer by the number of gallons you just put in to fill up. That's your mileage for that week. Keep a log. Do this at every fillup (Assuming you fill up at every fuel stop, instead of just putting $5 here and $7.49 there, etc.). If you start to notice a drastic decrease in mileage over time, then you have an indicator of something possibly needing to be addressed ... air filter, fuel filter, etc. You should be getting around 22-27 mpg. Link to comment Share on other sites More sharing options...
dxrflyboy Posted February 5, 2006 Share Posted February 5, 2006 I'll second that. The only way to accurately measure gas mileage is actual miles/actual gallons used. Link to comment Share on other sites More sharing options...
dmanaenk Posted February 5, 2006 Share Posted February 5, 2006 Weel, to make it accurate one would have to make sure he uses the same gas station and the same pump. Link to comment Share on other sites More sharing options...
