Apply 22 pounds of pressure to the following point:
Midway between the alternator and crank pulley on the power-steering belt.
New Belt deflection: .27-.35 inches
Old/Used Belt Deflection: .35-.43 inches
For the other belt--Apply 22 pounds of pressure to the following point: Midway between the Airconditioning and the crank pulley on the airconditioning belt.
New Belt deflection: .29-.33 inches
Old/Used Belt Deflection: .33-.39 inches
Source: Alldata Automotive Repair Manual on CD-Rom
How do you apply exactly 22 pounds? I don't know.
trained with they showed a tension scale that looked sort of like a scale you use to weigh fish. I never used one myself and never knew anyone who did.
What I have seen with belts that is more of a problem is universal types that are just a bit thinner than stock that don't run correctly in the pulleys.
Now of course we have serpentine blts that cause tensioner problems and cost more to rectify than some of my first cars.
I just push down on the belt for deflection and if it squeaks I tighten a bit more.
