Subarian Posted February 6, 2006 Share Posted February 6, 2006 I've owned 2 turbo wagons, and both had the pushbutton 5 speed, which makes me wonder, how common is the d/r with the 3.7:1 ratio? Link to comment Share on other sites More sharing options...
Caboobaroo Posted February 6, 2006 Share Posted February 6, 2006 there were two models of dual range turbo trannys avalible. First off was the part time dual range 5-speed that came in the '85 and '86 RXs and some of the '85 and '86 GL-10 wagons/sedans. I know of one '85 GL-10 turbosedan from back home that had the tranny and I had a '85 GL-10 turbosedan parts car that had the tranny as well. The other dual range turbo tranny was the Full Time RX tranny. Came with either a "4 high" or a "4 low" but then you had the center diff lock switch to lock it front to rear 50/50. Link to comment Share on other sites More sharing options...
