NewDriverOlderRide Posted February 6, 2006 Share Posted February 6, 2006 Umm is there like a light in the dash that comes on when you press the pushbutton 4WD? J/w If there is, I think I need to change some fuses. Link to comment Share on other sites More sharing options...
heartless Posted February 6, 2006 Share Posted February 6, 2006 not 100% sure on the 93, but would think so - there is on the older ones...it comes on in the center part of the dash - where the little image of the car is.... Link to comment Share on other sites More sharing options...
85Sub4WD Posted February 6, 2006 Share Posted February 6, 2006 yes, you should have a light first question - are you actually in 4WD?? the light comes on via a sensor in the transmission - if there is a problem with the 4WD actuator, then the 4WD won't engage, and the light won't come on - if the engage mechanism is working, then check the wiring leads between the sensor and the dash, and the indicator lighbulb itself - something isn't right good luck Link to comment Share on other sites More sharing options...
