warning:don't be stupid!!!
quebechatch
For the ones thinking of installing a roll cage in there car, I would suggest you put in a 4 or 5 points harness too, because without it your only protecting your car from being crushed. in my case It was a really good thing we were not wearing our seatbelts .
Wow, yea thank god you all were okay. Been in two Roll-overs in my life (none when I was driving) and they were both the scariest things I've been through...after seeing those pics though, my lifted Roo is getting a cage/good seats & belts before I do anything else major.
Man I hated seeing those photos...scary. Especially considering that I have had a few close brushes with endo-ing in my Hatch. Just a couple weeks ago I didn't make it over the top of a super steep hill climb and when backing down it the rear wheels dropped into a hole and stopped the car suddenly. I nearly soiled myself when the front wheels lifted off the ground momentarily and I thought the car was going over backwards. Guess the roll cage needs to be put back on the to-do list.
A few years ago I was toying with the idea of using a pre-fabbed six point cage made for VW bugs. I test fit it and found that it was a perfect fit for Hatchbacks. The wall thickness is thinner than SCCA requires but with added gussets etc, one of these cheapo cages would should hold up for rollovers.
Yeah I had a roll-over going backwards at 35mph crushed my hand send blood squrting out the ends of my fingers,,,,, not fun
Dr, I like your new avatar
