DeathHatch Posted February 7, 2006 Share Posted February 7, 2006 i have an ea81 and was wondering if it would be at all possiable to slap on an ea82 power steering pump..? or does the ea81 only work with the ea81 powersteering pump..? Link to comment Share on other sites More sharing options...
1984subaru Posted February 8, 2006 Share Posted February 8, 2006 The only way u will be able to do it is to make sure all the hoses and wire r the right connectors and lengths and the pumps r very simular. Link to comment Share on other sites More sharing options...
hatchsub Posted February 8, 2006 Share Posted February 8, 2006 I would save yourself the headaches and just find a pump, mounts and all the hoses for an EA81. They are entirely different beasts so im sure it would be a PITA to swap a pump from an EA82 in. Just my 2 cents. Link to comment Share on other sites More sharing options...
85Sub4WD Posted February 8, 2006 Share Posted February 8, 2006 if it is not an EA81-turbo, I doubt it is possible, because the belt routing is COMPLETELY different and so are the pumps, however if it is an EA81-turbo, I think it is possible Link to comment Share on other sites More sharing options...
GeneralDisorder Posted February 8, 2006 Share Posted February 8, 2006 Actually, yes - it's been done. The pump will bolt in, you just have to figure out the belt situation - the alt is used as the tensioner in the EA82, so you may need to measure and find a belt the right size. Just a V belt tho so shouldn't be hard at all. Measure with some string. Might need to find or fabricate the mount for the pump from an EA81T tho.... GD Link to comment Share on other sites More sharing options...
zyewdall Posted February 8, 2006 Share Posted February 8, 2006 If you're thinking about kludging an EA82 pump on there, why not just save yourself the trouble and leave the pump out completely? Although my '84GL had a power steering pump, it was disconnected (no belt, no hoses). Still seemed to work fine. Link to comment Share on other sites More sharing options...
GeneralDisorder Posted February 9, 2006 Share Posted February 9, 2006 If you're thinking about kludging an EA82 pump on there, why not just save yourself the trouble and leave the pump out completely? Although my '84GL had a power steering pump, it was disconnected (no belt, no hoses). Still seemed to work fine. Um.... because it wouldn't be "power" steering then would it? Power is awesome for off-roading with lifted soobs. Much superior to manual. Not a kludge either - the EA82 pump is the same as the EA81 turbo pump, so not all that strange to consider doing this. GD Link to comment Share on other sites More sharing options...
hatchsub Posted February 9, 2006 Share Posted February 9, 2006 Go here http://www.ultimatesubaru.org/forum/showthread.php?t=52677 If he decides to sell it it will make it easy for you...well as easy as it can be. Link to comment Share on other sites More sharing options...
Caboobaroo Posted February 9, 2006 Share Posted February 9, 2006 Go here http://www.ultimatesubaru.org/forum/showthread.php?t=52677 If he decides to sell it it will make it easy for you...well as easy as it can be. YEAH! But I'm not in Washington.......:-\ Link to comment Share on other sites More sharing options...
hatchsub Posted February 9, 2006 Share Posted February 9, 2006 YEAH! But I'm not in Washington.......:-\ Oh sorry about that Caboobaroo. I didnt read all the way through your post. I really should start doing that. Link to comment Share on other sites More sharing options...
