How to adjust idle
You can only adjust the IAC up or down about 100rpm, if that. Mine
was idling at 1500 for a while. I cleaned the IAC and it dropped to 1100.
I changed the CTS and it went down to 750 where it should be. Make sure
your throttle cable isn't too tight and the throttle arm is moving freely.
Don't touch the throttle stop screw.
I do not know what the IAC or the CTS is. I think I can pass by disconnecting the PCV system. It brings the Idle down to a rough 400. Normally I would try to fix it right but I cant legaly drive the car cuz it hasnt been registered for over a year, and I need to start driving it tomarrow. Thanks.
if you look close at the back of the throttle body, youll see a flat head screw adjustment for the idle facing up. iirc, if you rotate it clockwise, idle will lower. turn it CCW to raise the idle.
