Crawlerdan Posted February 8, 2006 Share Posted February 8, 2006 how the hell do i adjust the struts on the front of my 86 gl? i figured out the rear, but the front? they have the bolts in the bottom Link to comment Share on other sites More sharing options...
Crawlerdan Posted February 8, 2006 Author Share Posted February 8, 2006 do i need to rtemove the struts ant move em around?? Link to comment Share on other sites More sharing options...
MilesFox Posted February 8, 2006 Share Posted February 8, 2006 turn the nuts on the bolts ont he bottom of the dtrut. soak them down with your favorite lube and tund the nuts so they move up, thus compressing the spring. turn the alternately between one side and the other, and count the turns/threads or use a tape measure between the hub/tire and the fender Link to comment Share on other sites More sharing options...
Crawlerdan Posted February 8, 2006 Author Share Posted February 8, 2006 what size is that nut?? 21? 20? Link to comment Share on other sites More sharing options...
MilesFox Posted February 8, 2006 Share Posted February 8, 2006 they should be 19mm if im not mistaken. if not it could be 22 mm(7/8") Link to comment Share on other sites More sharing options...
