boostusmaximus Posted February 8, 2006 Share Posted February 8, 2006 Can anyone tell me where the knock sensor is located on a 1987 Subaru XT. The Chilton book simply says on the block. The knock sensor is the last code I have to clear and the car should run fine. Are there any secrects to a bad knock sensor, kinda like how the coolant sensor is always just the corroded wires? Thanks, Dan Link to comment Share on other sites More sharing options...
Dylan86GL10 Posted February 8, 2006 Share Posted February 8, 2006 Its on the top of the block and the rear, next to the turbo, in front of the bellhousing. Some have two wires and some one. 86 has two. Link to comment Share on other sites More sharing options...
boostusmaximus Posted February 9, 2006 Author Share Posted February 9, 2006 Thanks, I saw that sensor but hoped it might be somewhere else. Looks like I have to take a lot of things off just to get to it. I priced one at Auto Zone $149.99. Ouchh, is there anywhere else cheaper? Thanks, Dan Link to comment Share on other sites More sharing options...
Dylan86GL10 Posted February 9, 2006 Share Posted February 9, 2006 Junk yard. I had to pull the intake to get mine out. Luckily I was pulling the motor. Link to comment Share on other sites More sharing options...
