I just put two KC daylighters on
sounds like a bad alternator. This same thing happened to me when I hooked all 4 lights up on the Brat I'm driving plus the stereo which has 2 10" subs behind the seats. You might wanna put an EA82 alternator on since it has a little more amps runnin from it or search for the GM alternator swap
thanks for the tip ill try that. ive been running two batteries to keep it going but it still goes dead, but ill put a new one in, well thanks for your help
mark D :headbang:
By "not keeping a charge" do you mean the battery won't hold a charge when the car's off, or it's not charging when the car is running? If the latter, does it make a difference whether the lights are on or not?
If it won't hold a charge when it's off, you ought to check your wiring. If it won't hold it when it's running, your alt could be kaput or just not big enough, or your wiring could have a minor short somewheres.
