offroadbryan Posted February 10, 2006 Share Posted February 10, 2006 ok everyone i have a 2000 outback 5 speed 2.5. power everything. and other front windows howl. whats wrong? is it the seals? they dont leak water but i can hear the wind over the radio? any ideas? thanks Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted February 10, 2006 Share Posted February 10, 2006 ok everyone i have a 2000 outback 5 speed 2.5. power everything. and other front windows howl. whats wrong? is it the seals? they dont leak water but i can hear the wind over the radio? any ideas? thanks Lower the windows and squeeze/'pinch' the black triangular 'gusset' at the front. Use your palms and push inward on the mirror area part and outward on the 'tweeter' area on the inside. If that doeas not reduce the noise enough, there may be an adjustment from inside the door. Train your self to close the door by pusing on the metal - not the glass. Try a search on this issue - quite common. If that does NOT help, you may need to beging placig pieces of tape in different areas to pinpoint the problem. If the windshield or wiper blades/arms have ever been replaced, they could cause wind noise too. Link to comment Share on other sites More sharing options...
offroadbryan Posted February 18, 2006 Author Share Posted February 18, 2006 that actually worked! its a quick fix thank you Link to comment Share on other sites More sharing options...
