Eric Barr Posted February 11, 2006 Share Posted February 11, 2006 I have had several newer Subarus in the past few years and two of them (Outback Wagon and presently an '03 Baja) "miss fire " for a few miles after each gas fill-up. Local dealer is not familiar with this as a recurring problem with Subarus but both mine do this. Any of you had this experience ? It would help if I could tell them what to look for. Many thanks. Link to comment Share on other sites More sharing options...
PAezb Posted February 11, 2006 Share Posted February 11, 2006 I have had several newer Subarus in the past few years and two of them (Outback Wagon and presently an '03 Baja) "miss fire " for a few miles after each gas fill-up. Local dealer is not familiar with this as a recurring problem with Subarus but both mine do this. Any of you had this experience ? It would help if I could tell them what to look for. Many thanks. Are you filling right up to the brim of the gas cap filler tube, or stop when the gas pump auto stops. Subaru recommends not to fill up past when the gas pump stops (think it has something to do with allowing pressurization in the tank, not sure). Maybe a weak fuel pump? Other than that, brand of gas, winter gas (oxygenated vs non-oxygenated). My older subaru is finicky about Holiday Station Gas here in Minnesota - I never buy there unless it's an emergency and they're the only one around. Link to comment Share on other sites More sharing options...
sea#3 Posted February 11, 2006 Share Posted February 11, 2006 They should have a look at the canister purge control solenoid , it maybe sticking open and allow the vapors from the carbon canister to enter the manifold when they shouldn't SEA#3 Link to comment Share on other sites More sharing options...
Eric Barr Posted February 11, 2006 Author Share Posted February 11, 2006 It happens wherever I get gas. I njever fill past the automatic cutoff. Link to comment Share on other sites More sharing options...
PAezb Posted February 11, 2006 Share Posted February 11, 2006 It happens wherever I get gas. I njever fill past the automatic cutoff. Does the CEL light up? Link to comment Share on other sites More sharing options...
Eric Barr Posted February 11, 2006 Author Share Posted February 11, 2006 Nope. Is that the "check engine light"? It does not come on. Link to comment Share on other sites More sharing options...
Strakes Posted February 11, 2006 Share Posted February 11, 2006 My 2002 does this when I go to certain gas stations. I don't know why. It hesitates and misses until the computer figures out what's going on. I think it happens when you switch grades, or brands of gas...but it happens so rarely now because I've stuck with the same gas station. I know that certain stations here have ethanol added, and others dont. Maybe its the particular fuel density because of the temperature or pressure oe the addition of ethanol or other additives. I know that fuel's density can change with temp, and a sudden change might throw off something? These are just wild a** guesses. If mine hesitates, it goes away after a couple miles. Link to comment Share on other sites More sharing options...
dxrflyboy Posted February 11, 2006 Share Posted February 11, 2006 Subaru has been putting Champion spark plugs in from the factory for a while now. The replacement plugs available at the dealer are NGK. I'm sure it's a money thing and nothing else. If your car has Champion plugs in it, replace them with NGK or Bosch Platinum. If that doesn't solve your problem, you will have to dig deeper. Link to comment Share on other sites More sharing options...
Green96GT Posted February 12, 2006 Share Posted February 12, 2006 You're engine's missing after filling up? Did you try looking on the pavement next to the gas pump? Link to comment Share on other sites More sharing options...
nate_k Posted February 12, 2006 Share Posted February 12, 2006 You're engine's missing after filling up? Did you try looking on the pavement next to the gas pump? that was my first reaction when i read the title too! Link to comment Share on other sites More sharing options...
ShawnW Posted February 12, 2006 Share Posted February 12, 2006 Subaru has been putting Champion spark plugs in from the factory for a while now. The replacement plugs available at the dealer are NGK. I'm sure it's a money thing and nothing else. If your car has Champion plugs in it, replace them with NGK or Bosch Platinum. If that doesn't solve your problem, you will have to dig deeper. The champion plugs are used to keep the car having a certain percentage of american made parts. Certainly not used for their quality. Link to comment Share on other sites More sharing options...
'05 STi Posted February 12, 2006 Share Posted February 12, 2006 Maybe you're just getting the "bottom of the barrel," so to speak. When gas is running low at the pumps there is a higher percentage of water at the bottom of their tanks. I always "top off" and have never had a problem. I have about 12,200 miles on my car. Link to comment Share on other sites More sharing options...
PAezb Posted February 12, 2006 Share Posted February 12, 2006 The champion plugs are used to keep the car having a certain percentage of american made parts. Certainly not used for their quality. Nah, I thinks it's all about the bottom line...initial cost to produce vs sales profit. You'd be amazed how many sub-components are assembled in Mexico, for example, on the new models. What criteria requires Subaru (Subaru or outside entity) to maintain a percentage of American made components? What do they care? Link to comment Share on other sites More sharing options...
cookie Posted February 13, 2006 Share Posted February 13, 2006 I understand a certain amount of US bits is necessary to call the car US made not just assembled. My BMW is the same way. Link to comment Share on other sites More sharing options...
JohnVT Posted February 13, 2006 Share Posted February 13, 2006 Subaru has been putting Champion spark plugs in from the factory for a while now. The replacement plugs available at the dealer are NGK. I'm sure it's a money thing and nothing else. If your car has Champion plugs in it, replace them with NGK or Bosch Platinum. If that doesn't solve your problem, you will have to dig deeper. Don't put Bosch plugs in your Subaru. I used to get annoyed by the kid at the local car parts place who always made a big deal about that, until I had problems. I replaced the new Bosch Platinums with NGKs and the missing went away...?? Some on this board will differ with this, but it sure made a difference for me. Link to comment Share on other sites More sharing options...
