WagonsOnly Posted February 14, 2006 Share Posted February 14, 2006 Before I post this to the WTB forum, I want to find out whether or not what I want actually exists from the factory: -Were '87 and later RXes ever available with a brown interior? I need a brown hi-rise console and a brown shifter surround for a d/r full time 4wd--with the diff lock switch cutout--to complete my grey to brown interior swap on Tony's old RX wagon. Was this ever an option or do I have to find some plastic paint? Thanks, Andrew Link to comment Share on other sites More sharing options...
subaru_styles Posted February 14, 2006 Share Posted February 14, 2006 to break it down.. a brown(tan) high rise will be found in loyale with automatic seatbelts. the sifter trim needs to be pieced together to make a brown "RX" style console. you will need 1 brown d/r console/shifter trim, and 1 brown small square riser with diff lock swtich from a single range fulltime w/diflfock Link to comment Share on other sites More sharing options...
subaru_styles Posted February 14, 2006 Share Posted February 14, 2006 i just put a new console in my turbo coupe, and i love the high rise:banana: Link to comment Share on other sites More sharing options...
Turbone Posted February 14, 2006 Share Posted February 14, 2006 Sorry for the HJ, but how did you mount the hirise? I know the rear is attached to the seatbelt brackets, did you make a seperate mount? Link to comment Share on other sites More sharing options...
TROGDOR! Posted February 14, 2006 Share Posted February 14, 2006 I don't ever recall seeing a Loyale with a brown interior. Far as I know they only offered blue and gray. Link to comment Share on other sites More sharing options...
misledxcracker Posted February 14, 2006 Share Posted February 14, 2006 My '86 GL has a tan/brown interior... but I have never seen a DL or Loyale with that color. Link to comment Share on other sites More sharing options...
wagonzonlysr Posted February 14, 2006 Share Posted February 14, 2006 WagonsOnly said: Before I post this to the WTB forum, I want to find out whether or not what I want actually exists from the factory: -Were '87 and later RXes ever available with a brown interior? I need a brown hi-rise console and a brown shifter surround for a d/r full time 4wd--with the diff lock switch cutout--to complete my grey to brown interior swap on Tony's old RX wagon. Was this ever an option or do I have to find some plastic paint? Thanks, Andrew Try shoe polish ?? Link to comment Share on other sites More sharing options...
WagonsOnly Posted February 14, 2006 Author Share Posted February 14, 2006 Hmm. I think I'll just put in a standard brown d/r console and move the diff lock switch...I like the XT handbrake, though, nice touch. Thanks for your input. Also, there was a red Loyale on eBay a few months ago with a tan interior, and Meeky Moose has a brown DL wagon with brown interior. So yes, they are out there. Link to comment Share on other sites More sharing options...
Subarian Posted February 14, 2006 Share Posted February 14, 2006 I found the tan shifter surround with the diff lock switch at my local pick-n-pull, so I know they made them. Link to comment Share on other sites More sharing options...
Subi81 Posted February 14, 2006 Share Posted February 14, 2006 What about keeping the single range shifter with the button on the top and wireing the diff lock to that button, you will get a clean install and still keep the James Bond button. All you have to do is drill a hole in the stick shift. I know it is not ideal just a thought Link to comment Share on other sites More sharing options...
TROGDOR! Posted February 14, 2006 Share Posted February 14, 2006 The brown interior was quite common on the mid 80's models... and I believe all red 85-86 DL's came with brown interiors unless otherwise ordered. Andrew, what year was that Loyale? There's a billion of them running around this town, and in the junkyard as well, and I still have yet to see one with a brown interior. Link to comment Share on other sites More sharing options...
subaru_styles Posted February 14, 2006 Share Posted February 14, 2006 well loyales did not have the 85-86 "brown" interior, they got tan/light brown Link to comment Share on other sites More sharing options...
fangster Posted February 14, 2006 Share Posted February 14, 2006 I agree with SubaruSytles - I have just procured a tan hi-rise console from the US. I am going to get the paint matched and paint it blue. I know your pain - I was trying to get similar parts. It's worse when you are in Australia. I have found someone good enough to send me the parts I require. In lieu, im sending HIM parts he can't get in the US. Link to comment Share on other sites More sharing options...
LiftedHatchSubie Posted February 14, 2006 Share Posted February 14, 2006 Turbone said: Sorry for the HJ, but how did you mount the hirise? I know the rear is attached to the seatbelt brackets, did you make a seperate mount? I swapped out my lower one for a hi-rise and just took the old bracket from the car I got the hi-rise from and it all just fell into place in the existing screws...didn't have to change anything. Link to comment Share on other sites More sharing options...
Turbone Posted February 14, 2006 Share Posted February 14, 2006 The hi rise for the EA81 is different than the EA82. The EA82 hi rise only came from cars that have the auto seatbelts and the bracket is part of the seatbelt assembly. Which makes it a pain to install unless you fab a bracket for the console. But it looks like SS doesnt want to answer my question:-p Link to comment Share on other sites More sharing options...
subaru_styles Posted February 14, 2006 Share Posted February 14, 2006 Turbone said: . But it looks like SS doesnt want to answer my question:-p DOH! i skipped your post rob, anyway the front 2 bolts at the change tray line up, for the screw(s) inside of the compartment do indeed bolt to a bracket that is part of the lap belts for the autoblets, its eaiser to just make a bracket out metal strapping. also on the high rise ther is a lower piece that wraps around the back of it at the floor, i could get it to fit due to the pressence of my seat buckles Link to comment Share on other sites More sharing options...
WagonsOnly Posted February 15, 2006 Author Share Posted February 15, 2006 The Loyale I saw had a tan interior (as stated). It was a '94 red 5sp 4WD wagon. I can't keep the pushbutton shifter because scrapdaddytatum already put a d/r tranny in the car. On the other hand I did get a center console out of a '97 OBS that might be going in instead...we'll see what happens. Link to comment Share on other sites More sharing options...
TROGDOR! Posted February 15, 2006 Share Posted February 15, 2006 When I installed my high rise console in my RX I did it a little differently. Yes the screws in front do line up. I unbolted the seatbelt buckles and slid them through the slots for the automatic belts, bottom end first, then bolted them back down. If I remember right there is a bracket way down on the bottom that the low console screws into from the sides- I just drilled holes in the sides of the high rise console to correspond with them, and put in some long screws. Works like a charm. Link to comment Share on other sites More sharing options...
Turbone Posted February 15, 2006 Share Posted February 15, 2006 Thanks for the input on the bracket. I was anticipating on fabing something for mine, but I will take a look at the other method also. Link to comment Share on other sites More sharing options...
