64DD Bus Posted February 15, 2006 Share Posted February 15, 2006 Hey, Anyone out there seen, heard of or done a transplant into a split window VW bus? I am quite interested in doing this, however, if someone has done it, maybe you have some advice? I just don't know where to put that darn radiator. I am looking at inside the engine compartment, one on either side to catch the air from the intake louvers. Also is it necessary to cut any metal from the engine compartment? Maybe you bug guys can chime in on that as our compartment outlines must be the same. Let me know, Thanks much, Chris Link to comment Share on other sites More sharing options...
TheSubaruJunkie Posted February 15, 2006 Share Posted February 15, 2006 There's a complete forum dedicated to Subie - VW Swaps. They call it the Vanagon forum. -Brian Link to comment Share on other sites More sharing options...
64DD Bus Posted February 16, 2006 Author Share Posted February 16, 2006 Sorry, I don't have a vanagon. It is a 1964 double door, split window bus. An entirely different animal. The Vanagon guys don't know much about the early buses. Thanks anyway. Link to comment Share on other sites More sharing options...
volkswitt Posted February 16, 2006 Share Posted February 16, 2006 this site is not very active but search though it and you will find much good info including the mysterious aussie belly radiator http://bb.bbboy.net/vwengineconversions Link to comment Share on other sites More sharing options...
volkswitt Posted February 16, 2006 Share Posted February 16, 2006 oh be sure and search the samba http://www.thesamba.com Link to comment Share on other sites More sharing options...
ShawnW Posted February 16, 2006 Share Posted February 16, 2006 Vanagon guy here... Look at Kennedyeng.com for a link or phone number and call to inquire on their catalog. I believe the bellhousing and starter are pretty much the same so mounting the engine should be as well the same as a Vanagon. From there, the wiring is virtually the same for any car to mount a 2.2 just put power where power is needed and add gauges. Wiring a Subaru ej22 isn't terrible. Cooling will be your fun. I did an air cooled Vanagon conversion with 2 days worth of success. Overheated it and bailed on the conversion to dump the guts into a water cooled one with A/C. Figure out where to put a Radiator and whether or not you want a heater core/heat and go from there. I heard rumor that there were busses made in Mexico with h20 cooling but never dug around on that. Link to comment Share on other sites More sharing options...
64DD Bus Posted February 16, 2006 Author Share Posted February 16, 2006 Thanks for all the info. Yes, there are actually some Brazillian busses with water cooled engines and the radiators are up front. I really want to do this with the radiator hidden. There appears to be room inside on either side of the engine compartment. If I do a split radiator and mount one on each side, there should be enough cooling area, just not sure about air flow. The area is about 15 inches square on each side. How big is the standard radiator? Link to comment Share on other sites More sharing options...
idosubaru Posted February 16, 2006 Share Posted February 16, 2006 Sorry, I don't have a vanagon. It is a 1964 double door, split window bus. shows how good the subaru guys are, he goes to them for answers! Link to comment Share on other sites More sharing options...
ShawnW Posted February 17, 2006 Share Posted February 17, 2006 The vanagon radiator? Its a BEAST! Id say its 2.5" thick like a 3 row maybe and its at least 24x24 if not 30x30. Im having trouble picturing it in my head. Link to comment Share on other sites More sharing options...
64DD Bus Posted February 18, 2006 Author Share Posted February 18, 2006 Anyone know if the 2.2L can be set into a standard air cooled bug/bus engine compartment without cutting any sheet metal on either side? I measured a 2.2 at 29" wide and the opening in my bus looks to 29-1/4" wide. Any protrusions that may get in the way? I figure that the rear skirt may need a little mod, maybe not. Thanks, Chris Link to comment Share on other sites More sharing options...
bluesbug Posted February 18, 2006 Share Posted February 18, 2006 My 60 VW panel van has an EA81 engine and it fit EASILY in the engine compartment,and I used the KEP adapter. The radiator, a stock 80's suby was put in front of the engine cover,on hinges so it can tilt out, and a modified engine cover was installed.It has 2 cooling fans(electric) that pull air in from the back.It cools fine,but restricts engine access somewhat. Look at my other posts for pix and more info. Link to comment Share on other sites More sharing options...
a97obw Posted March 15, 2006 Share Posted March 15, 2006 Since one of my other cars is a 66 VW Microbus, complete with howling gear reduction boxes, a 1543.8 single port engine with dual Kadron carbs, and what my friend calls the DHMF (here is a clue....the DH stands for Ditch Hunting....you can guess the rest!) 4 wheel drum brakes that are ALWAYS a surprise as to which way the bus is going to go when you put the brakes on......I think you'd be WAY ahead of the game to measure the wheelbase/track of a legacy and compare that to the bus, then swap the legacy body for the bus body and retain things like an airbag!! Link to comment Share on other sites More sharing options...
Jack in Norfolk Posted March 15, 2006 Share Posted March 15, 2006 Since one of my other cars is a 66 VW Microbus, complete with howling gear reduction boxes, a 1543.8 single port engine with dual Kadron carbs, and what my friend calls the DHMF (here is a clue....the DH stands for Ditch Hunting....you can guess the rest!) 4 wheel drum brakes that are ALWAYS a surprise as to which way the bus is going to go when you put the brakes on......I think you'd be WAY ahead of the game to measure the wheelbase/track of a legacy and compare that to the bus, then swap the legacy body for the bus body and retain things like an airbag!! And a working heater!! Link to comment Share on other sites More sharing options...
