adding 4wd
What is the likelihood that you could add 4wd to a 2wd Loyale/GL wagon? I found a nice little wagon, but it has a couple problems 1; it's 2wd 2; it's auto. However, I know of another locally that is 4wd and manual.
Can you swap that in without huge headaches?
ses it be so! i have a 2wd at sedan converted to 4wd 5spd.
just so long as you have all the parts its all bolt on for the m ost part
you will, however, ,have to m ake a mount for the driveshaft. you will have to drill so me holes in the back and use bolts to m ount the rear diff hanger
