Alex GL-10 Posted February 22, 2006 Share Posted February 22, 2006 Will the flywheel out of a 86 5-spd non-turbo d/r GL or 89 FWD 5-spd GL work for an 89 5-spd turbo AWD GL? Link to comment Share on other sites More sharing options...
erik litchy Posted February 22, 2006 Share Posted February 22, 2006 im pretty sure Link to comment Share on other sites More sharing options...
Alex GL-10 Posted February 22, 2006 Author Share Posted February 22, 2006 erik litchy said: im pretty sure Pretty sure either will work? Link to comment Share on other sites More sharing options...
85Sub4WD Posted February 22, 2006 Share Posted February 22, 2006 you'll need the 4WD flywheel - the clutch is very different for the 2WD car - they all interchange on the engines, but I think the 4WD flywheel should be identical so that it will mount to the tranny as well Link to comment Share on other sites More sharing options...
Alex GL-10 Posted February 23, 2006 Author Share Posted February 23, 2006 85Sub4WD said: you'll need the 4WD flywheel - the clutch is very different for the 2WD car - they all interchange on the engines, but I think the 4WD flywheel should be identical so that it will mount to the tranny as well Does it matter if it comes off of a carbed non turbo engine? Link to comment Share on other sites More sharing options...
Qman Posted February 23, 2006 Share Posted February 23, 2006 The flywheels are all the same. The pressure plates are different. Link to comment Share on other sites More sharing options...
suberdave Posted February 23, 2006 Share Posted February 23, 2006 im pretty sure the clutch on a 2WD is smaller than on a A/4WD. -=Suberdave=- Link to comment Share on other sites More sharing options...
GLCraig Posted February 23, 2006 Share Posted February 23, 2006 suberdave said: im pretty sure the clutch on a 2WD is smaller than on a A/4WD. -=Suberdave=- N/A 2wd is smaller but a turbo 2wd is the same diameter as 4wd/awd but the dampening springs in the disk are different. Link to comment Share on other sites More sharing options...
Qman Posted February 23, 2006 Share Posted February 23, 2006 EA81's had different sized flywheels for 2 and 4 wheel drive. EA82 did not. Only difference will be the pressure plates. Link to comment Share on other sites More sharing options...
MilesFox Posted February 23, 2006 Share Posted February 23, 2006 on ea82 between front drive and 4wd flywheels, they bolt on the same but the inside where the disc goes the area is smaller, so a 4wd disc wont fit on the fwd flywheel ALL 4WD 5spds clutch/flywheel parts all fit the same, as well as driveshafts Link to comment Share on other sites More sharing options...
Alex GL-10 Posted March 12, 2006 Author Share Posted March 12, 2006 I got the flywheel, clutch disk, pressure plate, clutch cable, pedal assembaly off of a 86 4WD D/R non-turbo carbed GL. I put it on my 89 AWD turbo GL-10. The problem I have is that I can press the pedal all the way down and the clutch wont disengage all of the way. I have the cable adjusted all the way back so the fork is tight. Any suggestions on what I can do. Link to comment Share on other sites More sharing options...
