where's my oil going?
OK, I had a brief overheating issue because some idiot topped off the coolant level with H2O after fixing a radiator leak last summer, and when we got some real cold weather it froze up. It seems like right after that, I started noticing increased oil leakage, but I am not sure where it is coming from. All I know for sure is that it ends up on hot exhaust pipes, because I can smell it when stopped. Any ideas what to look for? Thanks.
(88 GL wagon)
by the sound of it, you could easily have a cracked head/block - while aluminum does allow a lot of expansion/contraction, it does have limits, and freezing it will break stuff
do what Phizinza said, and degrease, look for new, and that should give you a good idea as to where it is comming from - at best it will be a gasket (could even be valve cover gaskets, which are prone to leaking) - at worst, something will be cracked
good luck!!
